Solar Thermal Optics - Concentrated Light
The discussion focuses on calculating the heating energy potential of solar thermal systems using parabolic mirrors. The typical solar energy received is about 1000W/m2, translating to 0.1W/cm2, but this value varies based on location and conditions. To estimate the energy increase from concentrated sunlight, one should multiply the area of the reflector facing the sun by its efficiency and the target area receiving sunlight. The efficiency of the mirror and the absorption characteristics of the target material also play crucial roles in the calculations. Understanding these factors is essential for optimizing the design and performance of solar thermal devices.
Steven B
Hi,
Can someone start me out with creating predictable temperatures and inputs for calculations.
Here is a miniature example of the type of parabolic circulated water heating devices I have been building.
My first questions would be what is the potential heating energy of the sun per cm2?
And can I simply multiply that, by the cm2 area of the heating target (copper tube) receiving sunlight, and then by the surface area of the parabolic mirror, to calculate the increase in energy due to concentrated sunlight?
I definitely have additional questions to follow!
Thanks in advance,
Steven
Science news on Phys.org
The usual figure quoted is 1000W/m2 but it depends on where you live, time of day, time of year, the weather so will probably be lower.
1000W/m2 = 0.1W/cm2
First multiply by the area of the reflector facing the sun. That's not the same as the curved surface area of the reflector. It also changes if the reflector isn't pointed correctly at the sun.
Then multiply by a number between 0 and 1 to account for the efficiency of the mirror (the mirror absorbs some energy). I think a reasonable figure for a good mirror might be 90% or 0.9.
If the reflector is well designed (right curve) then all of that energy arrives at the target. If not well designed then some will miss the target. Assume well designed or pick your own figure?
Not all of the energy that arrives at the target will be absorbed by it. So again multiply by another number between 0 and 1. This depends on how reflective it is. Something like a matt black anodised pipe would be quite good (perhaps assume x0.9). A polished chrome plated pipe much lower (0.1?).
Likes russ_watters
PS If you know the flow rate for the water going through the pipe and can measure the temperature going in and coming out then you can calculate the power captured.
I'm going to re-read your second part to absorb it (no pun intended) better.
But I thought 1kw per square meter was just the potential photovoltaic electrical energy. Interesting.
The reflective surface is mirror grade stainless. The target pipe is 1/2 copper with black stove paint coating. I'll have to look up the gps of the pump.
I do know that the amount of heat gathered by a parabolic is related to it's diameter, " ... Not it's surface length. Photons do not compress, but they can be culmative on a focal point... Yes?
It's the amount of energy from the sun that arrives at the Earth's surface. See..
http://www.reuk.co.uk/wordpress/solar/solar-insolation/
I think most PV panels are only about 20% efficient so at best produce around 200W per sqm.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
