Is 0.025 M Considered a Highly Concentrated Solution?
  • Thread starter Thread starter steven10137
    Concentration
A concentration of 0.025 M is generally considered low for a highly concentrated solution, but context matters. In the case of acetic acid mixed with water, the original concentration of the acid is crucial for determining its classification. The discussion clarifies that the acetic acid used is glacial acetic acid, which is nearly pure and thus can be viewed as a concentrated solution despite the diluted final concentration. For the second question regarding Fe2+ concentration, converting from molarity to grams per liter and then to ppm is the correct approach, leading to a final concentration of approximately 502.65 ppm. Understanding the context of the substances involved is key to interpreting their concentrations accurately.
steven10137
Hi all, I have 2 short questions, that have caused me trouble in my study.
Firstly,
What is generally considered to be a highly concentrated solution?
eg. 250mL acid in 10L water.
This is 250E-3/10 = 0.25/10 = 0.025 M.
Would that be considered a concentrated solution? as it seems very low ...
Secondly,
In a sample of ground water, iron in the form of Fe2+ was found to have concentration 9.00E-3 M. Assuming the density of water is 1.00 gmL-1, what is the concentration of Fe2+ in ppm?
Now I'm not really sure what is going on here, but given the Fe2+ has a molar concentration of 9.00E-3, surely there is a way to convert that to gL-1 and then to mg/kg (ppm solute/solvent form)?
am i correct?
(just need to be lead on the right track there ...)
cheers
Steven
Firstly,
Hey :smile:
To calculate the molarity of the final solution, youre going to need to know what the concentration of the original 250mL acid solution is, so you can find how many moles in the final solution.
Hey sup
The question for the first part I am working on doesn't actually state any other values for me to work with. It states; "Household vinegar can be produced by adding 250mL of acetic acid to 10L of pure water. Which of the following best describes the acetic acid".
The answer is; "a concentrated solution of weak acid"
Now what I worked out before (0.025M) I thought was pretty low for a high concentration.
Any ideas?
part a i got fine now... just another stupid misunderstanding ...
any other suggestions for part b?
For the second question, you are told the concentration of Fe+2 in mol/L. You should start by converting that to a concentration in g/L, and then g/mL. See if you can go from there.
Thanks for your help :)
[Fe2+]=0.009
=0.50265 g/L
=0.50265 x 10^3 mg/L
=502.65 mg/L
therefore
502.65 ppm
cheers
steven10137 said:
Hey sup
Any ideas?
The acetic acid referred to in the question is the glacial acetic acid used to make the more dilute vinegar (250 mL in 10L). It is essentially 100% acetic acid. Thus the 'concentrated solution of a weak acid" is the closest to the correct answer, however; it isn't really a solution at all since it is water-free. It's a pure compound.
