Solution for Infinite Series: 1/(1+n^2) Sum < pi/2
tobythetrain
Given the Infinite Series 1/(1+n^2) where n goes from 1 to infinity, show that the sum is less than pi/2.
1/(1+n^2)dx=arctanx
Series goes 1/2, 1/5, 1/10, 1/17, 1/26 and so on
I have tried to find a telescoping series, but I can't see to get the terms to cancel out. My next try was to find the partial sum of the series, but I seem to want to take the integral from 1 til n+1 (as a form of partial sum) of 1/(1+n^2). I end up with Arctan(1+n) - Arctan(1), which obviously is less than pi/2, but I don't find this as a credibal solution...
Could anyone try to give me any hints on which way to go, or what way to go?
Thanks for welcoming me to the forum!
tobythetrain said:
1/(1+n^2)dx=arctanx
This is nonsense; perhaps you mean \int \frac{dx}{1 + x^2} = \arctan x + C ?
You are on the right track, actually. One small problem is that you need to overestimate the "bar graph" of the sum of the series with the curve, and \frac1{1 + x^2} is a decreasing function of x, which means you need to move the "bar graph" left to fit under the curve. That is, for the n = 1 term, you need to write \frac1{1 + 1^2} &lt; \int_0^1 \frac{dx}{1 + x^2} and not \frac1{1 + 1^2} &lt; \int_1^2 \frac{dx}{1 + x^2} (which is false). If what I said about bar graphs doesn't make sense, draw a few pictures.
2. I tried to write the integralsign, but couldn't find it so I did it the easy way...
I totally see it now, and my problem is solved. Thanks a lot for helping me! This is a wonderful forum!
Toby
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
