Solution of the 1D heat equation
8 replies · 4K views
Betsy
$$\frac{\partial T}{\partial t}=\alpha\frac{\partial^2 T}{\partial^2 t}$$
with an initial condition and boundary conditions
$$T(x,0)=T_0$$
$$T(L,t)=T_0$$
$$-k\left.\frac{\partial T}{\partial x}\right|_{x=0}=2A\cos^2\left(\frac{\omega t}{2}\right)=A(\cos\omega t+1)$$
where $A=V_0^2/(8RhL)$, $V_0$ is the voltage applied to the heater, R the electrical resistance of the heater, h the thickness of the thin film, $\alpha$ the thermal diffusivity of the thin film, and $\omega/2$ the heating frequency. The solution for this problem is
$$T(x,t)-T_0=\frac Ak\sqrt{\frac\alpha\omega}\exp\left (-\sqrt{\frac{\omega}{2\alpha}}x\right)\\ \times\cos\left(\omega t-\sqrt{\frac{\omega}{2\alpha}}x-\frac\pi4\right)-\frac Ak(x-L)$$I got this from a paper. I'm trying to derive how the author came to the solution from the boundary conditions. There is no derivation in the paper, and I searched books and the internet thoroughly but couldn't find anything. I attached the solution I'm getting. But I don't think it's correct! Any help regarding where I'm doing wrong will be greatly appreciated.
Orodruin said:
That solution does not satisfy the boundary condition at x=L.
But it was published in a good journal by a very renowned professor (now). They must have some logic behind it which is unfortunately not mentioned in the paper.
Can you provide a link to the paper in the journal? Your PDF attachment does not include the beginning of the paper with that information. Thanks. :smile:
Betsy said:
From the sentence below the solution, it is said that the B.C. is reasonably well satisfied because A approaches 0 for the experimental parameters chosen.
And indeed if A equals 0, you do get the B.C. satisfied.
Like I told you in the other forum that you and I have been interacting in, the authors of this article implicitly assume that the oscillatory part of the solution damps out before it reaches x = L. The condition for this to happen is ##\sqrt{\frac{\omega}{2\alpha}}L>>0##.
In your analysis, Eqn. 17 is incorrect. It should read (based on the above assumption), $$a(x)=C_1\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\cos{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}+C_2\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\sin{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}$$
You are missing factors of 2 in the denominators of the square root terms in your expression.
To obtain b(x), you substitute this corrected form of Eqn. 17 into your Eqn. 14. What do you obtain?
Maybe it would help also if I told you that the four roots of of ##x^4=-1## are
$$x=\frac{1+i}{\sqrt{2}}$$
$$x=\frac{-1+i}{\sqrt{2}}$$
$$x=\frac{-1-i}{\sqrt{2}}$$
and $$x=\frac{1-i}{\sqrt{2}}$$
This is where the ##\sqrt{2}## comes from in the correct form of Eqn. 17.
In a previous post, I indicated that the solution for a(x) is $$a(x)=C_1\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\cos{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}+C_2\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\sin{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}$$
If I substitute this into your Eqn. 14, I obtain: $$b(x)=C_1\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\sin{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}-C_2\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\cos{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}$$But, applying the boundary condition on b(x) at x = 0, we have that ##C_2=0##. This means that $$a(x)=C_1\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\cos{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}$$ and $$b(x)=C_1\exp{\left(-\sqrt{\frac{\omega}{2\alpha}}x\right)}\sin{\left(\sqrt{\frac{\omega}{2\alpha}}x\right)}$$
In your Eqn. 11, you have the wrong sign on A/k. You got to do the math correctly.
