Solve a Trig Equation Containing secant
  • Thread starter Thread starter nickb145
    Secant Trig
To solve the equation sec(5x) - 5 = 0, it can be rewritten as cos(5x) = 1/5. The inverse cosine function yields a principal solution of θ = cos⁻¹(1/5) = 1.36, which gives x = 1.36/5 = 0.2738. Additional solutions can be found by considering the cosine function's periodicity, leading to other valid angles in the first and fourth quadrants. The discussion emphasizes the importance of recognizing the periodic nature of trigonometric functions when finding all solutions.
nickb145
sec(5x)-5=0
I turned it into 1/cos(5x)=5 x=θ/5
then i switched it to cos(5x)=/1/5
Then cos-1(1/5)=θ which = 1.36 (one solution) then divided by 5 which is .2738 which works as one solution
since the positive cos is in the 1st and 4th quadrant i need to subtract 2pi to 1.36= 4.91 then divide by 5 which gives me .9827 which also works
But i am stuck after that
nickb145 said:
sec(5x)-5=0
then i switched it to cos(5x)/1/5
And lost your equation.
You're making this harder than it needs to be. If 1/cos(5x) = 5, then cos(5x) = 1/5.
You could also say that cos(5x + k*2##\pi##) = 1/5, and since cosine is positive in Q IV, you could also say that cos(-5x + k*2##\pi##) = 1/5, where k is an integer.
Now you can take cos-1 of both sides.
