Solve ab+cd Given a^2+b^2=c^2+d^2=1 and ac+bd=0
  • Thread starter Thread starter Kizaru
The problem involves real numbers a, b, c, and d, constrained by the equations a² + b² = c² + d² = 1 and ac + bd = 0. The goal is to determine the value of ab + cd.
  • Participants discuss various algebraic manipulations and relationships derived from the given equations, including attempts to express variables in terms of one another and explore geometric interpretations.
Several participants have shared their attempts at deriving the relationship between the variables, with some expressing uncertainty about their calculations. There is a recognition of potential elegant solutions, and multiple lines of reasoning are being explored without a clear consensus on the approach.
Participants note the challenge of working with three equations involving four unknowns, leading to various assumptions about the variables, including cases where one or more may be zero.
Kizaru
Suppose that a, b, c, d are real numbers such that a^2 + b^2 = c^2 + d^2 = 1 and ac + bd = 0. What is ab + cd?
[tex] a^{2} + b^{2} = c^{2} + d^{2} = 1[/tex]
[tex]ac + bd = 0[/tex]
Clearly, ac = -bd. I know the solution is 0, but I am having trouble proving or deriving it.
A few things to note (some may be useless, but this is an involved problem and I'm getting my hands dirty):
[tex] <br /> (a + c)^{2} + (b + d)^{2} = a^{2} + b^{2} + c^{2} + d^{2} + 2(ac + bd) = 1 + 1 = 2[/tex]
[tex] (a + d)(b + c) = ab + ac + bd + cd = ab + 0 + cd = ab + cd<br /> [/tex]
And there are many other expressions like these, but not sure how to piece them together. The first equation tells me that the hypotenuse of a rectangle with sides (a+c) and (b+d) is sqrt(2).
The second equation tells me the area of a rectangle with sides (a+d)(b+c) = ab+cd, assuming that one value is < 0. I know there is something else I'm missing, just not sure what it is.
Any help would be greatly appreciated.
I really think there should be an elegant solution. For the time being, here's a brute force approach: You have three equations in four unknowns. You can solve for three of the variables in terms of the fourth, and use that to conclude that ab + cd = 0.
If one of the numbers is zero, it is pretty straight forward to show that ab + cd = 0. So let's assume that all variables are nonzero. Then you can use ac + bd = 0 to solve for a in terms of the other variables: a = -bd/c. Plug that into a^2 + b^2 = 1 to get d in terms of b and c. Then plug that into c^2 + d^2 = 1 and see what you get. I don't want to spoil the surprise!
I tried that approach earlier and obtained
[tex] c^{2}(2-\frac{1}{b^{2}}) = 1[/tex]
I was unable to manipulate it any further into something meaningful.
It feels like I am missing something from this approach as well.
Hmm, I will double-check my own calculation but I ended up with b^2 = c^2 and a^2 = d^2.
If a = -bd/c, then
[tex]a^2 + b^2 = b^2 d^2 / c^2 + b^2 = 1[/tex]
so
[tex]d^2 = c^2 (1-b^2) /b^2[/tex]
[tex]1 = c^2 + d^2 = c^2 + c^2 (1-b^2) /b^2 = c^2 \left(1 + \frac{(1 - b^2)}{b^2} \right) = \frac{c^2}{b^2}[/tex]
Hence [tex]b^2 = c^2[/tex].
owlpride said:
If a = -bd/c, then
so
OH, I see my mistake. I had
[tex]a^2 = -\left(\frac{bd}{c}\right)^2[/tex]
Which is why I had the 2 inside the parentheses.
And from there we get a^2 = d^2 as well, and since one must be negative to satisfy ac+bd= 0 blah blah ab+cd = 0.
Thank you very much!
interpret it as perpendicular vectors with norm 1:a=sin(t)
b=cos(t)
c=sin(t+pi/2)=cos(t)
d=cos(t+pi/2)=-sin(t)
ab+cd=0
boboYO, that is a very interesting solution. Thank you!
11K
