Solve Angular Velocity: \theta=60deg, \alpha=-2w^2
The discussion focuses on calculating angular velocity given angular acceleration and position. The angular acceleration is defined as α = -2ω², and the problem involves finding the angular velocity at θ = 60 degrees, starting from θ = 30 degrees with an initial velocity of 10 rad/s. After some calculations, it was determined that the correct limits for integration should be from π/6 to π/3, leading to the conclusion that the angular velocity at θ = 60 degrees is approximately 3.51 rad/s. The initial miscalculation of 1.14 rad/s was corrected through proper integration and application of logarithmic properties. The final confirmation of the correct answer was achieved with the help of the forum participants.
Bingo1915
[SOLVED] Angular Velocity
1.
The angular acceleration is given \alpha=-2w^2 rad/s^2 where \omega is the angular velocity in rad/s. When \theta=30 deg the angular velocity is 10 rad/s. What is the angular velocity when \theta=60deg?
2.
Used \alpha=d\varpi/d\theta * \varpi
3.
\int-2 d\theta=\int1/\varpi d\varpi
after integration I got
[\(-2)*theta]=[ln\varpi]
limits 0-60 for \theta and 10 to \varpifor \varpi
I think I'm missing a step somewhere. The book gives an answer of w=3.51. With my calculations I get w=1.14. Can you advise?
Redo the calculation. Book is correct. The limits of theta should be from pi/6 to pi/3.
Using pi/6 to pi/3 I get
-2pi/3 + pi/3 = lnw-ln10
-pi/3 + ln10 = lnw
From here I think it is
1/[e^(-pi/3+ln10)] = w
Can you check me on this part?
e^(-pi/3+ln10) = w [ln a = b ie e^b = a]
-pi/3 + ln10 = lnw
ln 10/w = pi/3. Take antilog of pi/3, use a calulator (or something) => w = 3.51.
(By antilog, I meant, 10/w = e^pi/3. You have done everything correctly.)
I see where I was incorrect.
Thanks for the help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
