Solve Basic Entropy Help Homework Statement
  • Thread starter Thread starter jchojnac
    Entropy
The discussion revolves around calculating the entropy of two identical microscopic objects, A and B, based on their energy states and the number of ways to arrange that energy. For object A at 6e-21 joules, and object B at 1e-20 joules, the entropy can be determined using the formula S = kln(omega), where omega represents the number of arrangements for each energy state. Participants express confusion about deriving the quanta from the given energy values and emphasize that the number of arrangements directly correlates to the entropy calculation. The combined entropy of the system, SAB, is simply the sum of the individual entropies, SA and SB. This approach simplifies the problem by focusing on the provided data rather than complex calculations.
jchojnac
Object A and object B are two identical microscopic objects. The table below shows the number of ways to arrange energy in one of these objects, as a function of the amount of energy in the object.
E (joules) 4e-21 6e-21 8e-21 1e-20 1.2e-20 1.4e-20 1.6e-20
# ways 6 20 37 60 90 122 148
When there are 6e-21 joules of energy in object A, what is the entropy of this object?
SA = ? J/K
When there are 1e-20 joules of energy in object B, what is the entropy of this object?
SB = ? J/K
Now the two objects are placed in contact with each other. At this moment, before there is time for any energy flow between the objects, what is the entropy of the combined system of objects A and B?
SAB = ? J/K
omega = (q+N-1)!/q!(N-1)!
S = kln(omega)
I don't know how to get the quanta from the energy given...if that's how you do it? When i know the quanta i can find omega and and plug it into the entropy equation.
E: 4e-21, 6e-21, 8e-21, 1e-20, 1.2e-20, 1.4e-20, 1.6e-20
# ways: 6, 20, 37, 60, 90, 122, 148
This might be easier to read
S = kln(omega)
There is a more basic definition for S=k·ln(#), where # is the number of states it is possible for the system to be in.
The formula using q and N seems to a way to calculate the number of states for a particular scenario ... however in this problem it is much easier to get #, just using the number of ways to arrange the given energy.
Hey I have the same problem and I don't know how to do it as well
Can someone please help me?
What do you need to do after finding all of the S?
S = k*ln(omega)
k= boltzman's constant
Boltzmann constant = 1.3806503 × 10-23 m2 kg s-2 K-1
omega= (q+n-1)!/q!(n-1)! = Number of ways
basically look at the energy asked and used the number of ways under for omega.
SAB = SA + SB
It worked for me hope i Helped
