Solve Beer's Law: Find Phenolphthalein Concentration from 0.80 Absorbance Unit
  • Thread starter Thread starter TrueStar
    Law
To find the concentration of phenolphthalein from an absorbance of 0.80 at 560nm using Beer's Law, the equation A = e*b*c must be applied. The path length (b) is typically 1 cm, while the molar absorptivity (e) for phenolphthalein is estimated to be around 1770 M^-1 cm^-1 at 20°C and basic conditions. However, the problem lacks sufficient information to calculate the concentration directly, as the exact value of e may vary with temperature and pH. The discussion highlights the need for additional details, prompting the user to consult their lab instructor for clarification. Ultimately, the calculation cannot proceed without the molar absorptivity value.
TrueStar
If I measure an absorbance at 560nm of 0.80 absorbance units for a solution of the basic form of phenolphthalein, what is the concentration of phenolphthalein?
Beer's Law -- A(sub lamda)=e*b*c
The question is asking for concentration, so I'll need to solve for c. I think A is the absorbance units, but beyond that I believe I'm missing information.
b is supposed to be the path length, which I believe is the width of whatever cuvet is being used (the problem doesn't specify what that is). e is molar absorbtivity, but isn't that a constant?
Is this problem able to be solved as it is or do I need more information?
Thanks!
Cuvet length is 1 cm by convention. Molar absorptivity is going to vary with temperature and pH as you can see here:
http://pubs.acs.org/doi/full/10.1021/ol016823q
Unfortunately they don't report a value for phenolphthalein but estimating from Fig. 6, e should be about 1770/(M.cm) at 20C and basic conditions.
Thank you for the reply. It seems there was no way to calculate an answer based on the question alone. I was worried I was missing something obvious.
I will ask my lab instructor about it next week.
I agree 1 cm is a common cuvette size, but calling it a "convention" is too far fetched.
Quite right, I stand corrected.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
