Solve Cartesian Product Without Symbol: Find Answers Here
  • Thread starter Thread starter momentum
    Cartesian Product
The discussion revolves around the confusion regarding the use of symbols in Cartesian products within relational algebra. Participants clarify that the Greek letter rho (ρ) is used for renaming relations to avoid attribute clashes, which is essential when joining similar entities like employees. There is disagreement about the notation used in the book for presenting relations, with some suggesting that the format is incorrect and lacks clarity. A specific issue is raised about the notation "x <-" and "y <-", which is not commonly found in relational algebra, leading to further confusion. Overall, the conversation highlights the need for clearer explanations and better resources on relational algebra.
momentum
<Moderator's note: Moved from a technical forum and thus no template.>
Here is a problem and solution given in my book.
this is using a symbol in cartesian product .
I checked other books for cartesian product examples but there was no such symbol being used.
Here is my solution without that symbol
Is my solution wrong ?
I'm confused.
I just looked this up. That is the greek character rho (##\rho##) which means rename according to wikipedia. So employee is renamed to e, books to b, loan to c, then it creates the cartesian product. Does that help?
okay. But is my solution correct ?
I am not renaming. Can I do this ?
I don't want to mislead you but for some reason I have an inkling that it may be necessary in the relational algebra to use rename when attributes would clash. So for example, if you were joining from employee to employee and matching each staff member to their manager, it would be necessary to use rename. I think in this problem it isn't necessary.
Why did you write employee x books x loan at the top? Should it not be in line with the rest?
View attachment 232159Here is my solution without that symbol
View attachment 232160Is my solution wrong ?
I'm confused.
Without more context, especially the definition of a relation algebra, it is hard to tell.
##\rho## is the Greek letter ##r##, so one might suspect that it stands for relation. Also is it indexed by the three categories, which might indicate that ##\rho_{\text{employee}} \times \rho_{\text{books}} \times \rho_{\text{loan}}## is simply the phase space of all possible relations, resp. their tables in the database.
Likes momentum
I believe notation of sigma says, at the top you put name of the relation and at bottom you put the condition. There is no in line stuff with this syntax. Is it wrong ?
Wow I'm confused by your how your book has written these answers. I believe the answer to A given in the book should look like this (there was a typo):
$$\pi_{name} (\sigma_{e.empno = l.empno \land l.isbn = b.isbn \land b.publisher = 'McGraw-Hill'} (\rho_e(employee) \times \rho_l(loan) \times \rho_b(books)))$$
And I don't know what is going on with answer B. It just doesn't look right to me.
In your answer, I don't think putting the relation at the top is correct. Sorry, I'm doing the best I can to help.
verty said:
Wow I'm confused by your how your book has written these answers. I believe the answer to A given in the book should look like this:
$$\pi_{name} (\sigma_{e.empno = l.empno \land l.isbn = b.isbn \land b.publisher = 'McGraw Hill'} (\rho_e(employee) \times \rho_l(loan) \times \rho_b(books)))$$
okay . I understand answer to A now.
But I am confused with answer to B.
What does these mean ?
x<--
y<---
I checked relational algebra notations but could not find such notations. And so I'm stuck to understand solution B .
If solution B is not correct solution. What is the right solution ?
x<--
y<---
If this is not correct solution. What is the right solution ?
I thought it meant "Select ... as x , select ... as y , ... where ... " but I don't understand the minus in ##x-y##. Shouldn't it be an ##AND\,?##
B should be something like:
##\rho_e(employee), \rho_l(loan), \rho_b(books)##
##x \leftarrow (\pi_{isbn} (\sigma_{e.empno = l.empno} (e \times l))##
##y \leftarrow (\pi_{isbn} (\sigma_{publisher = McGraw-Hill} (b))##
##\pi_{name} (\sigma_{j.isbn = l.isbn \land l.empno = e.empno} (e \times l \times \rho_j(\sigma (x - y))))##
Oh wait, this is not correct but I don't have time to fix it. This answers a different question but it's similar.
That x-y means tuples in x but not in y.
Likes fresh_42
x<--
y<---
I think you may need a better book. Anyway, I don't want to explain every little thing. I think I have done the best I can here. That book looks to be particularly poor, I must say.
