Solve for Football Field Goal: Height & Time Calculations"
  • Thread starter Thread starter night_stroller
The discussion revolves around solving a quadratic equation that models the height of a football during a field goal attempt. The equation h = -4.9t^2 + 10t + 3 describes the ball's trajectory, with h representing height in meters and t representing time in seconds. Participants discuss how to determine when the ball reaches the ground and how long it stays above 5 meters, emphasizing methods like completing the square and the quadratic formula. There is a suggestion that completing the square is not necessary if the quadratic formula can be used instead. The conversation highlights the importance of understanding quadratic functions in solving real-world problems like field goal attempts.
night_stroller
hi,
Can somebody please help me solve this through completing the square?
A football player attempts a field goal by kicking the football. The ball follows the path modeled by the equation h=-4.9^2+10t+3, where h is the height of the ball above the ground in metres, and t is the time since the ball was kicked in seconds.
a) Describe the path of the ball.
b) After how many seconds does the ball reach the ground?
c) The ball must clear the uprights for the field goal to count. The uprights are approximately 5m high. How long does the ball stay above 5 m in height?
Must you do it by completing the square? Why not use the quadratic formula?
We should have a mod roll call.
I haven't learned it yet.
Why not prove it then =] ? Completet the square on the general quadratic form ax^2 + bx + c, where a, b and c are real constants.
which bit are you stuck on exactly?
for a), its kind of you know it or you dont.
for b), when the ball hits the ground, you know its height is what?
from there you can simply solve the quadratric using the quadratic formula (be useful if you can derive it, but just search google if you can't be bothered).
for c), same sort of method as b), just use a dif value for height.
need any more help?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
