Solve for the slope and length of a line segment
To solve for the slope and length of the hypotenuse of the right triangle defined by the shaded area, the area formula A = 1/2 * base * height can be applied, where the area is given as 4. The coordinates of the intercepts, (0, b) and (a, 0), can be used to express the base and height in terms of the slope m. By substituting these intercepts into the area formula, two equations can be derived to relate the slope and the dimensions of the triangle. Ultimately, using the point-slope formula will help find the slope and length of the hypotenuse. The problem requires careful manipulation of these relationships to arrive at the solution.
Husaaved
The problem is to a.) solve for the slope m of the hypotenuse of the right triangle indicated by the shaded area, and b.) solve for the length of the hypotenuse, if possible. I made a mistake in transcribing the problem onto paper, the line of course extends indefinitely but the shaded area and the length of the line bounded by the y- and x-axes are all that are of interest.
The area of the shaded area is 4, and a single point along the line are all that is given. I get also that a (0, y) and (x, 0) are also given, and I know that the point-slope formula is y - y1 = m(x - x1, but I'm not sure in what way to apply this information to the problem.
Any thoughts?
Any thoughts?
There are two pieces of information given, the area and a point on the line. A good starting point would be to write down the area in terms of a formula. ##A=\frac{1}{2}bh##.
You have two unknowns, so you need another equation so you can substitute variables to solve for the other.
Think about slope.
Edit: That might have been too vague. How can you relate x and y together using slope? Then use that relationship in the area formula to solve for x and y.
Any thoughts?
You know x1=2 and y1=1. Plug in these data into the formula y-y1=m(x-x1) *
Denote the X-intercept by a and the Y intercept by b. How do you get the shaded area in terms of a and b?
You get equations for a and b in terms of m by substituting (a,0) and (0,b) into eq. *.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
