Solve Limit at Infinity Problem: Tips & Help
9 replies · 3K views
Alexstrasuz1
Hi, I've been doing limit problems, and just got to this problem and I can't solve it. I would love some tips; you don't have to solve my problem.
Screenshot by Lightshot
What is the $2n+3$ doing? Your formatting is a bit weird. Is the limit
$$\lim_{n\to \infty}\left(1+\frac{3n-1}{n^2+1}\right)^{\!\!2n+3}?$$
Im supposed to get it to this lim(1+1/n)^n=e
I suggest the following:
Rewrite the exponent $2n+3$ as follows
$$\frac{(2n+3)(3n-1)}{3n-1} = \frac{6n^2+7n-3}{3n-1} = \frac{6(n^2+1)}{3n-1}+\frac{7n-9}{3n-1}$$
Then we can write the limit as
$$\displaystyle \left[\lim_{n \to \infty} \left(1+\frac{1}{\frac{n^2+1}{3n-1}}\right)^{\frac{6(n^2+1)}{3n-1}}\right]\left[\lim_{n \to \infty} \left(1+\frac{1}{\frac{n^2+1}{3n-1}}\right)^{\frac{7n-9}{3n-1}}\right]$$
The left limit is equal to $e^6$, the right limit is equal to $1$. Hence the solution is $e^6$.
I solved it by dividing fraction by n and got 3/n and then just did some standard work and got e6
In regard to the second factor, I can intuitively understand what you did, but Mathematically I am lost. How did you know the limit of the second factor is 1?
-Dan
-Dan
As $n\to\infty$, the base goes to $1$ and the exponent goes to a finite value (7/3) so we have a determinate form of $1$. :D
Hey I solved this on my way and today I showed it to my teacher and she said it isn't right way to solve it even I got the same result
I divided 3n-1/n^2+1 with n so I got 3/n and I wrote it as 1/n/3 and put that n/3=t where n=3t and I got in exponent 6t+3 and got that e^6.
If I understand you correctly, you mean:
$$\frac{3n-1}{n^2+1} \frac{1}{n} = \frac{3}{n}?$$
The only thing you could do is to divide the numerator and denominator by $n$ but I don't see how that could lead to a solution.
