What is the Maximum Load the Steel Bracket Can Support?
In summary: Yes, everything seems to be correct so far. Fazza3_uae has successfully completed the first three steps of the problem.
Fazza3_uae
51
Mechanics Question : Maximum Load needed ?? Urgent Please Help
http://img694.imageshack.us/img694/5462/66814773.jpg
A new steel bracket was designed to support various loads being hung from the end. The designer would like
to know the largest load that can be hung on the bracket.
What is known:
-Allowable yield stress for the steel is 36 ksi.
-The bracket safety of factor must be at least 2.
-Each arm of the bracket is 6 in long.
2. The Question
What is the maximum load that can be placed on the bracket?
First of all i converted all the units into SI units ,, Ksi into N/m2 & in into m
The question gave me the procedure to solve this problem but i am stucking on each step ,, so help is really appreciated friends.
The procedures given :
-Calculate the maximum torsion in the circular bar.
-Calculate the maximum bending stress in the circular bar.
-Determine the stress state at the wall (location of the maximum bending stress and torsional stress)
-Find the principal stresses and using the given factor of safety and the yield stress of steel calculate the
allowable Load.
For the first procedure :
Do they mean the shear stress or it is different .
I used This formula : σmax = T R / Ip
where , σmax is shear stress , T is the torque , R is bar of shaft radius , Ip is moment of inertia.
I found torque by using this formula : T = G * σall
G = Z = Ip/c
σall is given = 248.2e6 N/m2
I found these numbers please if there is any mistake please inform me ,,,
c = diameter / 2 = 0.009525 m
Ip = J = pi/2 * R4 = 1.2929e-8 m4
Then G = Z = J/c = 1.357e-6 m3
Then torque T = G * σall = 336.807 N.m
Finally i found shear stress to be = 248.13e6 N/m2
Which is as same as the σall that is given ,, Is this reasonable ??
Please correct the mistakes if found by you ,,, help me to finish the first step ??
Thx in advance for all.
Excellent work, so far, Fazza3_uae. Keep going.
Alright then let's move to the second step .
σBending max = M*c / Ip
where M is the bending moment.
c is the maximum vertical distance away from the N.A ( Neutral Axis)
Ip is the moment of inertia.
I found c to be the same as the radius which = 0.009525 m >>> Is it correct ??
Ip is what I've found in the first step >>>> I think this should be right ?
M the bending moment , Here I am confused a little bit , I know that moments and torques are calculated as a force multiplied by distance, but the question here is what force & distance shall i use if i have to use them to solve for M ??
Hmmm now am I going right or missing something ,, ??
Thx nvn for checking my solution
The applied force is given in the diagram. Let's call it P. Use the perpendicular distance of P from the wall. Ig is not equal to Ip. Try computing Ig again.
Ooops i think that I wrote Ig by mistake.Sorry
So now Ip is the same found in the 1st step right ..??
Ok the moment now must = 6 * P In SI units = 0.1524 * P
So
σBending max = 0.1524 * P * 0.009525 / 1.2929e-8
σBending max = 1.1228e5 *P N/m2
Thats it second step done ...
Now i want to move to step 3.
http://img14.imageshack.us/img14/7660/1copyjm.jpg
First of all , Did I locate the stresses correctly with directions , second how to find the components of the maximum bending stress or i don't have to find them ..?
So confused ,,, I am sorry nvn if i ask too much . I really apprectiate ur help.
The final Step
allowable Load.
I think that ,,
σx = 0
σy = + M*c / Ip ,
M = 1.1228e5 *P , c = 0.009525 m , Ip = 1.2929e-8
[tex]\tau[/tex]xy = + T*c / Ip ,
T = ??
Now finding principal stresses :
We only need the maximum here right ??
σmax = 0.5 * (σxy) + UnderSquare[ [tex]\tau[/tex]2xy + 0.5 * (σxy)2 ]
Then after that i use this formula
F.o.S = Ultimate stress / Allowable Stress
Ultimate stress = σMax. = what is found in the last step in terms of P
Allowable Stress = σall. = what is already given in the problem
F.o.S = 2
Is every thing seems good & right ..??
Switch the y and z axes in your diagram. Your value of J is correct, but your value of I is wrong. I is not equal to J. Try computing I again.
http://img268.imageshack.us/img268/1417/1copyr.jpg
Ok, I switched the z & y axes in my diagram but why u did that ...??
What about the location of stresses are they going to stay on there old localtion after switching...?? (( In this case I think that there woulb no more σy or [tex]\tau[/tex]xy. There would be σz & [tex]\tau[/tex]zx instead respectively ))
Hmmmm , my value for J I've used in the first step was for the only circular bar.
So do I = the moment of inertia for the whole system ...??
If it is right check my answer . [ The moment of inertia about the x-axis ]
I = (1/3)*(b*h3) + J
where b = 0.1524 m
& h = diameter i think = 0.0127 m
Am i going in the right direction ...??
You switched the y and z axes correctly in your diagram. No, do not switch your parameter nomenclature. Keep them as sigmay and tauxy. Your I is still wrong. I = pi*(r^4)/4.
Ok i will not change anything .
Hmm , Why it is divided by 4
what is the difference b/w this and J
When i calculated J i used R the radius of the shaft not the diameter.
Here you divided by 4 which means to me that r here represents the diameter not the radius... am i right ??
No, using your textbook, study or look up rectangular area moment of inertia, or rectangular second moment of area, which is called I, for a solid circular cross section. And also study polar area moment of inertia, or polar second moment of area, which is called J, for a solid circular cross section. You got J correct in post 1. But not I.
Stop using formulas for I and J. Instead, go back to first principles with I being the integral of dAy2 and J being ... (you do it). Then you will understand the difference.
Ok , i have read the textbook and found the difference b/w the Ip Or J and I
I found that the rectangular second moment of area I = pi*(r4)/4
Thanks NvN. Now i have one more question how to find T the torque here :
[tex]\tau[/tex]xy = = + T*c / I
T = ??
Thanks Pongo38 for the respond i knew the difference now and all the thanks go to NvN.
Very good, Fazza3_uae. Torque T = (distance)*P. Fill in the distance (moment arm) here.
yup , i have done it. thanks a lot NvN.
all credit goes to u . thanks a ton.
1. What is the definition of maximum load in mechanics?
The maximum load in mechanics refers to the maximum amount of weight or force that a structure, machine, or material can withstand before breaking or failing. It is an important factor to consider in engineering and construction to ensure the safety and stability of a structure.
2. How do you calculate the maximum load needed in a mechanical system?
The maximum load needed in a mechanical system can be calculated by analyzing the strength and properties of the materials used, as well as the design and structure of the system. This can be done through mathematical equations and simulations, taking into account factors such as stress, strain, and safety margins.
3. What are the potential consequences of exceeding the maximum load in a mechanical system?
Exceeding the maximum load in a mechanical system can lead to failure, collapse, or damage of the system. This can result in safety hazards, costly repairs, and even injury or loss of life. It is crucial to always ensure that the maximum load is not exceeded in any mechanical system.
4. How can you strengthen a mechanical system to increase its maximum load capacity?
There are several ways to strengthen a mechanical system and increase its maximum load capacity. This can include using stronger and more durable materials, optimizing the design and structure, adding reinforcement or support, and conducting regular maintenance and inspections to identify and address any weak points.
5. What are some common examples of maximum load in everyday life?
Examples of maximum load in everyday life can include the weight limit of elevators, the maximum load capacity of a bridge, the maximum weight a car can carry, and the maximum weight that can be placed on a shelf or table. It is important to follow these guidelines to ensure the safety and functionality of these systems.
9K
13K
  • Mechanical Engineering
