Solve Quadratic Equation: 2E(S+Wn)2
The discussion revolves around solving a quadratic equation presented in a somewhat unconventional format, specifically involving the Greek letter 'E' (xi) and its implications in the equation. Participants explore methods to approach the solution, including the use of the quadratic formula, while expressing varying levels of understanding and frustration with the complexity of the problem.
  • Homework-related
  • One participant expresses confusion about the quadratic equation due to the presence of the Greek letter 'E', suggesting it complicates their understanding.
  • Another participant proposes that 'E' should be treated as a constant, similar to a numerical value.
  • There is a suggestion to use the quadratic formula with identified coefficients a = 1, b = 2ξω_n, and c = ω_n².
  • Participants discuss the formatting of mathematical symbols and share tips on how to write them correctly in the forum.
  • One participant expresses frustration about the lack of prior exposure to the quadratic formula, feeling unprepared for the assignment.
  • Another participant acknowledges the algebraic mistakes made in the calculations and suggests reviewing foundational concepts.
  • There is a discussion about the derivation of the quadratic formula and the importance of understanding the underlying principles of quadratic equations.
  • A participant shares an update about receiving incorrect materials from their tutor, which contributed to their confusion.
Participants express a range of views on how to approach the problem, with some agreeing on the use of the quadratic formula while others remain uncertain about the calculations. There is no consensus on the best method to solve the equation, and several participants highlight their struggles with the material.
Participants note that the problem may be unreasonable given the limited prior exposure to the quadratic formula, which typically requires a more comprehensive understanding of quadratic equations, including factoring and completing the square.
This discussion may be useful for students encountering quadratic equations for the first time, particularly those struggling with the transition from simpler factoring methods to more complex applications involving the quadratic formula.
fordy2707
so I've been tasked with this insane question
obtain the solution of the following quadratic equation
how do I solve this, the 'E' (greek letter),is throwing me out,my complete hazardous guess is
2E(S+Wn)2 <--- 2 is a squared sorry my keyboard skills are lacking also 'tut'
any help greatly appreciated
Mathematics news on Phys.org
[math]s^2 + (2 \xi \omega _n)s + \omega _n^2 = 0[/math], I presume.
Use the quadratic formula. a = 1, [math]b = 2 \xi \omega _n[/math] and [math]c = \omega _n^2[/math].
-Dan
Hi fordy2707! Welcome to MHB! ;)
For the record, that greek 'E' is actually an 'x', or more specifically a 'xi' ($\xi$).
Anyway, as topsquark already suggested, just treat it as any other constant, say a $3$.
Oh, and if you have trouble writing that $\xi$, here's how it should be done:
haha ,how are you getting those symbols up ??
Type it as \$\xi\$.
Oh, and if you click Reply With Quote on topsquark's comment, you can see how the entire equation is formatted.
$\xi$ ${s}^{2}$
sorry if I am being totally stupid here (Doh) but is the answer to this quite literally
a = 1, [math]b = 2 \xi \omega _n[/math] and [math]c = \omega _n^2[/math]because i can't see how this can be calculated any further where I've just got symbols all over the place,
It's a quadratic equation in s for all it's apparent complexity. [math]\xi[/math] and [math]\omega _n[/math] are just numbers. So
[math]s = \frac{-b \pm \sqrt{b^2 - 4ac}}{2a}[/math]
If it's still too complicated looking switch out the [math]\xi[/math] for z and [math]\omega[/math] for w.
-Dan
- - - Updated - - -
i once had a Korean professor that called it "squiggly."
-Dan
once all is placed into the quadratic formula that's as far as I can go isn't it ?,as below that can't be calculated
So
[math]s = \frac{-2\xi\omega_n \pm \sqrt{2\xi\omega n^{2} - 4s\omega_n^2}}{2s}[/math]
If it's still too complicated look 'Into giving up' I think is what one might say (Smirk)
So
[math]s = \frac{-2\xi\omega_n \pm \sqrt{2\xi\omega_n^{2} - 4s\omega_n^2}}{2s}[/math]
a, b, and c are coefficients. s is the variable so you don't put that into the quadratic equation.
It looks like there is a common [math]\omega _n^2[/math] in each term under the radical...
Oh, and if [math]b = 2 \xi \omega _n[/math] what is b^2?
-Dan
[math]s = \frac{-2\xi\omega_n \pm \sqrt{4\xi\omega_n - 4\omega_n^2}}{2}[/math]
now I can't go further can I as the figures are different ?
or would we be looking at
[math]s = \frac{-2\xi\omega_n \pm \sqrt{\xi - 4\omega_n}}{2}[/math]
We have the quadratic equation [math]s^2 + (2 \xi \omega _n )s + \omega _n ^2 = 0[/math]
So we know that [math]a = 1[/math], [math]b = 2 \xi \omega _n[/math], and [math]c = \omega _n^2[/math]. Thus
[math]s = \frac{-(2 \xi \omega _n) \pm \sqrt{(2 \xi \omega _n)^2 - 4(1)(\omega _n ^2)}}{2(1)}[/math]
[math]s = \frac{-2 \xi \omega _n \pm \sqrt{4 \xi ^2 \omega _n^2 - 4 \omega _n^2}}{2}[/math]
[math]s = \frac{-2 \xi \omega _n \pm \sqrt{(4 \omega _n^2) (\xi ^2 - 1)}}{2}[/math]
Can you finish from here?
It's pretty basic stuff for this level but I've known a lot of students who completely lose their heads when Greek letters come into it.
-Dan
apprehensively I have
[math]s = \frac{-2 \xi \omega _n \pm (4 \omega _n) (\xi - 1)}{2}[/math]
A lot of algebra mistakes in this one from start to finish. You may want to brush up on some of this.
[math]\sqrt{(4 \omega _n^2) ( \xi ^2 - 1)} = \sqrt{4 \omega _n^2} \cdot \sqrt{\xi^2 - 1}[/math]
[math]= 2 \omega _n \sqrt{ \xi ^2 - 1}[/math]
-Dan
I would not get this in a million years , it's annoying that I'm learning from a given 4 page teaching sheet explaining quadratic equations using factorisation which is easy,the examples all easy so I go to my supportive assignment and out the blue comes questions needing the quadratic formula which I had no prior explanation of so YouTube helped me learn that which was fine but then this hideous question comes up jeez how an Earth am I expected to know this from 4 pages of factorisation .i can see how your progressing, but for me to do it from the original equation myself is never going to happen.
If you were only exposed to factoring, but not completing the square and the resulting quadratic formula, then you were dealt an unreasonable problem. Typically, quadratic equation are taught in 3 sections. First, factoring and then completing the square, and finally you are shown that you can take the general quadratic, and complete the square on it to derive the quadratic formula. Each section should have lots of application problems, but one should never expect a student to work the problem you were given after only being exposed to factoring.
So please don't feel bad...this was not fair to you. (Shake)
There's a couple of power rules that I think should be part of anyone's repertoire.
$$\sqrt a = a^{1/2} \\
(ab)^c=a^c b^c \\
(a^b)^c=a^{bc} \\
a^{-c} = \frac{1}{a^c}
Are you familiar with those? (Wondering)
In this particular case, we have:
$$\sqrt{4\omega_n^2 (\xi^2 -1)}
= \left(4\omega_n^2 (\xi^2 -1)\right)^{1/2} \\
= (4\omega_n^2)^{1/2}(\xi^2 -1)^{1/2} \\
= 4^{1/2}(\omega_n^2)^{1/2}\sqrt{\xi^2 -1} \\
= (2^2)^{1/2}(\omega_n^2)^{1/2}\sqrt{\xi^2 -1} \\
= 2^{2\cdot (1/2)}\omega_n^{2\cdot (1/2)}\sqrt{\xi^2 -1} \\
= 2^{1}\omega_n^{1}\sqrt{\xi^2 -1} \\
= 2\omega_n\sqrt{\xi^2 -1}
So I have an update, chatted with my tutor today and he apologised after realising he had sent me the wrong quadratic equations supportive question papers to what I had been learning ,which was factoring simple questions ,although to my horror I still have to learn this in my next module .distance learning this is going to prove very difficult.
Thanks everyone for your input here anyway , and very soon I shall hassle you with more.
Hassle away! (Wave)
-Dan
Huh? I thought it was a 'Z' (zeta)...
xi: $$\xi$$
zeta: $$\zeta$$
so to revive this (dread) ,having not fully learned this properly yet but not wanting to walk away ,im getting my head around how you come to
$= 2\omega_n\sqrt{\xi^2 -1}$
but I am just wondering why can we not calculate and remove the square root of
$\sqrt{\xi^2-1}$
to become
$\sqrt{\xi-1}$ ?
is it because you can't square root the whole figure,the -1
$\sqrt{\xi^2-1}$
to become
$\sqrt{\xi-1}$ ?
Just as [math](a+b)^2 \neq a^2 + b^2[/math] (You need to FOIL it out) so too [math]\sqrt{a^2 + b^2} \neq a + b[/math]
-Dan
