Solve RLC Circuit Problem - Get Help Now
The discussion revolves around solving an RLC circuit problem, specifically focusing on finding the time-domain current I(t) from its phasor representation I(ω). Participants explore the relationship between impedance, voltage, and current in the context of AC circuit analysis.
  • Homework-related
  • One participant expresses uncertainty about converting I(ω) to I(t) and mentions having calculated the total impedance of the circuit.
  • Another participant confirms the impedance calculation but notes a missing unit and suggests using Ohm's law to find the total current.
  • There is a discussion about the phase relationship between voltage and current, with one participant asserting that the current will not have the same phase as the voltage.
  • Participants discuss converting the phasor form of the current to the time domain, emphasizing the need to express it as a cosine function.
  • One participant questions their calculation of I(ω) and seeks clarification on transitioning to I(t).
  • A later reply points out that the participant has already calculated I(t) but had referred to it incorrectly as I(ω).
Participants generally agree on the method of using Ohm's law and the importance of phase relationships, but there is some confusion regarding the terminology and the conversion between I(ω) and I(t). The discussion remains unresolved regarding the correctness of the calculations and the final solution.
There are limitations in the discussion, such as missing units in calculations, potential misunderstandings about phase relationships, and the need for clarity in terminology regarding I(t) and I(ω).
tiger95
Member warned about not using the homework template
Hello, I have to solve the following problem but I don't know how to find the I(t) from I(ω). I've already found that the total impedance of the circuit should be (1000/29)-j(255/29). Can anyone help me, please? I haven't done Integration and Derivatives. Thank you for your help.
Hello tiger95, Welcome to Physics Forums.
Please note for future posts in the homework sections that it is mandatory to use the formatting template provided when the thread is started.
Since you have managed to calculate the impedance of the circuit (correct value but you forgot the units) then you should be able to use Ohm's law to find the total current. In phasor form the source voltage can be written as Vin = 2 V. That's a 2 V peak magnitude with no phase angle since the voltage source provides the reference angle. Peak values can be used here since you're not dealing with power calculations. If you were, you'd convert to RMS values.
Does that help you for part (a)?
If I use Ohm's Law to calculate I(t) the result would be: I(t) = V / Z = 2 / (1000/29)-j(255/29) = (80/1469) + j(102/7345) but there isn't the time in the answer. Moreover, I haven't understood why the current will have the same phase as the voltage.
It won't have the same phase as the voltage. The voltage acts as a reference for the phase. The current will have a phase with respect to the voltage. What's the polar form of the current that you calculated?
The current that you found is the phasor form of the current. Convert to time domain by writing it as a cosine function, just as the voltage was written. The angular frequency is the same as the source and you should have the phase from the polar form of the current phasor.
Here is how I managed to calculate I(ω) which I'm not sure it's right. Then, how can I change from I(ω) to I(t)?
You already have I(t). You've called it I(ω) but you should have been calling it I(t) or maybe I(ωt) from the very start.
Thanks to your hints, I managed to attempt a solution for the whole exercise. Can you confirm me that it's right, please?
  • · Replies 25 ·
