Solve SR Particle Velocity Homework Eqns for Kinetic Energy
To solve the kinetic energy of particles in the center of mass frame, the correct approach involves using the relativistic kinetic energy equation K = mc^2/(1 - v^2/c^2)^(1/2) - mc^2 and the energy-momentum relation E = ((pc)^2 + (mc^2)^2)^(1/2). The initial assumption that the kinetic energy would be half of the decay energy (179MeV) is incorrect because two pions are produced, not one. The discussion highlights the importance of correctly accounting for the number of particles created in decay processes. Understanding these concepts is crucial for accurately calculating kinetic energy in relativistic scenarios.
gnulinger
http://i.imgur.com/VVVAl.png
K = mc^2/(1 -v^2/c^2)^(1/2) - mc^2
I don't know how to find the kinetic energies of the particles in the center of mass frame. I thought that they should just be exactly half the energy released in the decay from 498MeV to 140MeV (i.e. 179MeV), but that is wrong.
Two pions are created, not one.
Thanks. I had just been working on the problem for a while and I was stuck in a rut.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
