Solve (t^2-1)y'' +4ty'+2y=6t, given two particular solutions
CGandC
Solve the DE ##\left(t^2-1\right) \ddot{y}+4 t \dot{y}+2 y=6 t ## if its two particular solutions are ## y_1=t ## and ## y_2=\frac{t^2+t+1}{t+1} ##.
method of variation of parameters ( possibly utilizing here Wronskian of linear non-homogeneous differential equation of second order order ).
I find a solution in math.exchange site: https://math.stackexchange.com/ques...neral-solution-given-two-particular-solutions
The way I thought about solving the problem is to somehow use the two particular solutions to generate a homogeneous solution, I couldn't figure out how to do so; but, the solutions proposed in the link above leave me with an uneasiness of mind because:
1. The first answer- i.e. that the linear combination of the particular solutions is one fundamental homogenous solution ( in which case, I can use the wronskian to find the other fundamental homogenous solution and then we're finished ) is a little bit tricky because how was I supposed to know that the sum of particular solutions may generate a homogenous solution? is there any theorem backing this?
2. The second answer - i.e. using the substitution ## u = (t+1)x ## will enable me to find the homogenous solution regardless of the given information about two particular solutions ( but i'll need information about one particular solution to generate a general solution ), so how does the knowledge of two particular solutions help me here? ( I only need one )
Thanks for the help!
This is a result from the general theory of linear maps: If \alpha(x) = \alpha(y) = b for linear \alpha then \alpha (x - y) = \alpha(x) - \alpha(y) = b - b = 0.
Ah, I see that now, in our case, the linear map is the differentiation operator over vector space of smooth functions over reals? ( because we wish to find such a smooth general solution )
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
