I Matrix Component Equation: Solving for B with Known Scalar and Indices
  • I
  • Thread starter Thread starter member 428835
member 428835
Solve $$A_{ij} = c B_{ij}+B_{kk} \delta_{ij}$$ for ##B## where ##c## is a known scalar and ##i,j,k## are indices and range either ##1,2,3## and ##\delta_{ij}## which is the Kronecker Delta..
I've thought to write this into a matrix but I'm unsure what to do with the ##B_{kk}##. Any help or guidance is greatly appreciated.
(This is from a book, so not exactly homework Thanks!
Josh
One of the very useful techniques to use when solving such matrix equations is to take the trace of the equation and then substitute the result back in. I am assuming the Einstein summation convention in being applied so that ##B_{kk}## actually means ##B_{11}+B_{22}+B_{33}##. Taking the trace yields ##A_{ii}=(c+3)B_{kk}##, so you just substitute ##B_{kk}## back in and you are done.
This technique is very useful, so hopefully you will remember it to apply to other problems.
Likes member 428835
Thanks for replying Lucas! So are you saying to rewrite the equation as $$A_{ij} = c B_{ij} + \frac{c}{c+3} A_{kk} \delta_{ij} \implies \\ B_{ij} = \frac{1}{c}A_{ij} - \frac{1}{c+3} A_{kk}\delta_{ij}$$ This totally makes sense! So that I understand, you use this trick whenever you have ##X_{ii}##, right? Also, do you have any other fancy tricks? :)
In the first line it is ##\frac{1}{c+3}## instead of what you wrote. Apart form that it is correct. Also I just realized that ##c+3## must be different than ##0## for this to work, otherwise you find ##A## to be traceless.
joshmccraney said:
This totally makes sense! So that I understand, you use this trick whenever you have XiiXiiX_{ii}, right?
Not necessarely, although that may be a strong indicator to use it. Use it whenever you want a way to reduce the degrees of freedom of the equation. When taking the trace you reduce the freedom from ##n^2## to ##1## for ##n## by ##n## matrices.
In general a matrix will have ##n^2## components, and it can always be separated into a symmetric and antisymmetric part. The symmetric has ##n(n+1)/2## independent components while an antisymmetric part has ##n(n-1)/2## independent components. The symmetric part can be further separated into traceless part and trace. So taking the trace is analogous to computing a component of a matrix equation. You can also symmetrize or antisymmetrize to reduce the number of equations.
Another very useful technique is diagonlising one of the matrices. This can help simplify a particular problem.
Thanks for catching the algebra mistake, and thanks for all your help!
