Solve the proof in problem involving logarithms
  • Thread starter Thread starter chwala
    Logarithms Proof
The discussion revolves around solving a logarithmic proof using the change of base formula. The user presents a series of equations to express relationships between variables x, y, and logarithmic terms. They derive a formula for the ratio of y to x, leading to the expression (1 - y/x) / (1 + y/x). Another participant questions the derivation of the ratio y/x and points out a missing term in the transition between steps. The conversation highlights the complexity of manipulating logarithmic identities and the need for clarity in each transformation.
chwala
If ##log_a n=x## and ##log_c n=y##, where ##n≠1##, prove that, $$\frac {x-y}{x+y}=\frac {log_b c-log_b a}{log_b c+log_ba}$$
understanding of logs
In my approach, i made use of change of base; i.e
$$x-y=\frac {log_b n}{log_b a} -\frac {log_b n}{log_b c}$$
$$x-y=\frac {log_b c ⋅log_b n - log_b n ⋅logba}{log_b a ⋅log_bc}$$
and
$$x+y=\frac {log_b n}{log_b a} +\frac {log_b n}{log_b c}$$
$$x-y=\frac {log_b c ⋅log_b n + log_b n ⋅logba}{log_b a ⋅log_bc}$$
$$→\frac {x-y}{x+y}=\frac {log_b n}{log_b n}⋅ \frac {log_b c - logba}{log_b c +log_b a}$$
$$=\frac {log_b c - logba}{log_b c +log_b a}$$
Any other way of looking at it...
\frac{y}{x}=\frac{log_na}{log_nc}=\frac{log_ba}{log_bc}
where b is any positive number. So we get the formula of
\frac{1-y/x}{1+y/x}
as requested.
\frac{1-y/x}{1+y/x}
as requested.
I do not seem to get what you did here...how did you arrive at this
Between the middle and the right terms, there is a term
\frac{\log_ba/\log_bn}{\log_bc/\log_bn}
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
