Solved Faraday's Law Problem: Find Correct Answer
  • Thread starter Thread starter neelakash
    Faraday's law Law
5 replies · 4K views
neelakash
[SOLVED] Faraday's law problem
Charge Q is uniformly glued over a thin (insulating) ring of radius R and mass m.The ring can rotate freely in horizontal plane about z axis.A magnetic field B is switched on along +z axis.The ring rotates with angular velocity w.
(A)w=0
(B)w= -(QB/2m)
(C)w= -(QB/m)
(D)w=(3/5)(QB/m)
I have rejected (A) and (D).Either (B) or (C) is correct...But,anyhow I cannot get the answer.Everytime I am ending up with dB/dt from Faraday's law...
Can anyone say what is correct?
There'll be an electric field induced, so what's the torque due to the electric field on the ring? And so, what's the angular momentum imparted to the ring? The [tex]\frac{dB}{dt}[/tex] will come up, but remember you're going to integrate over time to find the net angular momentum imparted.
If you do not mind,can you please only give me the answer?
I wrote (B) in an exam today...And I am really tensed about it...
The answer is (B), cause
[tex]\tau= \frac{Q}{2 \pi} \int E.dl = - \frac{QR^2}{2} \frac{dB}{dt}[/tex]
and [tex]L=\int \tau dt = I \omega[/tex]
Thank you very much...
Oh...I was getting crazy over it...
