Solving 600L of 30% Acid Algebra Problem
  • Thread starter Thread starter emma3163
    Algebra
To create 600 liters of a 30% acid solution using a 20% and a 50% acid solution, the correct setup involves defining variables for each solution. The calculations show that 400 liters of the 20% solution and 200 liters of the 50% solution are needed. This combination results in 80 liters of pure acid from the 20% solution and 100 liters from the 50% solution, totaling 180 liters of acid in 600 liters of solution. The final concentration confirms the desired 30% acid solution. The solution is validated through both the mathematical setup and the acid content check.
emma3163
A lab has a 20% acid solution and a 50% acid solution. How many liters of each are required to obtain 600 liters of a 30% acid solution?
.20x + .50(600 - x) = .30(600)
.20x + 300 - .50x = 180
-0.3x + 300 = 180
- 300 -300
-0.3x = -120
-0.3 -0.3
x = 400 liters
I am sure that the answer is wrong. Can anyone tell what I am doing wrong, or how to set the problem up properly?
Thank you
Your solution for x looks good to me, what does that mean the quantity of the 20% solution is? How about the 50% solution?
The only thing I see wrong with it is that you haven't yet answered the question.
"x= 400 liters" does not answer "How many liters of each are required to obtain 600 liters of a 30% acid solution?" For one thing, there is no "x" in the question and, for another, there are obviously two quantities required, not just one.
I presume that x represents the amount of 20% acid solution used. It is very good practice to SAY that at the beginning of the solution (if nothing else, it will really shock your professor!). You also have (600- x) in your formula and that, I guess, is the amount of 50% acid solution used. Well, 600- 400= 200, so your answer should be "400 liters of the 20% acid solution and 200 liters of the 50% acid solution must be used to make 600 liters of 30% acid solution."
Now, let's see if that is correct. Certainly 400+ 200= 600 liters so that gives the correct amount of solution. 400 liters of 20% acid solution contains .20(400)= 80 liters of pure acid. 200 liters of 50% acid solution contains .5(200)= 100 liters of pure acid so the 600 liters of mixture contains 180 liters of acid. 180/600= 18/60= 3/10= .30. Yes, that is a 30% solution.
thanks soo much!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
