Solving a 4 kg Particle's Velocity & Force
  • Thread starter Thread starter tjbateh
    Force Velocity
The problem involves determining the direction of the net force and the particle's direction of travel for a 4 kg particle with a given velocity function. The context includes concepts from dynamics, specifically relating to force, mass, and acceleration.
  • Participants discuss taking derivatives to find acceleration and relate it to force using Newton's second law. There are questions about the calculations of force components and the implications of the magnitude of the force.
The discussion is active, with participants exploring different interpretations of the force vector and its components. Some guidance has been offered regarding the calculation of the force vector and the subsequent steps to find the angle with the x-axis.
There is some uncertainty regarding the calculations, particularly in deriving the force vector and its magnitude. Participants express confusion about numerical values and the process of finding time.
tjbateh
The velocity of a 4 kg particle is given by v = (3ti + 6t^2j ) m/s, with time t in seconds. At the instant the net force on the particle has a magnitude of 38 N, what are the direction (relative to the positive direction of the x axis) of (a) the net force and (b) the particle's direction of travel?
I took the second derivative of V to get the acceleration which is 3(i) + 12t(j). What should my next step be?
Force=ma
so get that vector and use the fact that the magnitude is 38N to find the time.
so would that vector be (12(i) + 12t(j))? And I would set that equal to 38?
no you'd get F=12i+48tj
and |12i+48tj|=38. Find t
how did you get 48t??
a=3i + 12tj
m=4, finding ma, 12*4=48. Unless I am wrong as I am bad with numbers.
ok, so T = .54 seconds. what should I do next?
find the force vector (by subbing t=0.54)
then find the angle it makes with the x-axis. It's a similar process for part b
ok, the force vector is F= 1.62i + 1.75j
And the angle is 47.21 degrees? 47.21 is wrong though, i tried it.
  • · Replies 20 ·
  • · Replies 21 ·
