Solving a Bridge Circuit: Input Voltage, Resistances, and Output Voltage
  • Thread starter Thread starter ElBell
    Electrical
The discussion revolves around solving a bridge circuit with given resistances and an input voltage. Participants are attempting to determine the output voltage under specific conditions, including a change in one of the resistances. The scope includes homework-related problem-solving and application of Ohm's Law.
  • Homework-related
  • The initial resistances are R1=100 ohms, R2=200 ohms, R3=250 ohms, R4=300 ohms, with an input voltage of 3V.
  • One participant suggests using Ohm's Law to find the current and subsequently the output voltage, but expresses uncertainty about the approach.
  • Another participant explains that the equivalent resistance of parallel resistors is not simply the sum of resistances and describes the configuration of the bridge circuit.
  • A participant calculates the output voltage using a formula but appears to use incorrect values for some resistances in their calculations.
  • The output voltage is calculated as Eo=3V(R1/(R1+R2)) - (R3/(R3+R4)), with results provided for both the original and modified resistance values.
  • A later reply points out discrepancies in the resistance values used in the calculations, indicating potential errors in the earlier posts.
Participants do not reach a consensus on the correct approach or values to use in the calculations, and there are disagreements regarding the resistance values applied in the formulas.
There are unresolved issues regarding the correct application of formulas and the values of resistances used in the calculations. Some assumptions about the circuit configuration may not be fully articulated.
ElBell
A bridge initially has resistances equal to R1=100ohms, R2= 200ohms, R3= 250ohms, R4= 300ohms. Determine output voltage at this condition for an input voltage of 3V. What is the bridge output if R1 changes to 125ohms?
Havent been given any. I am assuming something to do with Ohms Law?
I used Ohms Law. But I don't know if I am on the right track.
I= E/ R
I= 3/ 850 = 0.00353 amps.
Now I don't know what to do. Or if I was even supposed to use this Law.
Any help would be much appreciated :) Thanks a lot.
I'm actually just learning about them myself so I could be wrong but I may be able to help. Firstly the equivalent resistance of parallel resistors isn't just the sum of resistances so that doesn't work because in a bridge you usually have two banks of resistors that are in series connected in parallel which is in turn connected to some sort of measuring device (galvanometer) at a point in between them.
So across that measuring device, you will have a positive and negative terminal and you want the potential difference between them
So, voltage across top of the circuit (current flows in direction of positive charge) = V = 3v
So the voltage in the (+) terminal is = V x (R2/ R(eq) of R1 and R2 in serial)
voltage in the (-) terminal is = V x (R4 / R(eq) of R3 and R4), just find the difference between them and I think that should be it.
Thanks for your help!
What does everything think of what I have done here?
Eo= Ei(R1/R1+R2) – (R3/R3+R4)
Eo= 3V (100/100+150) - )200/250+300)
= -.164V
Let us change R1 to 125 ohms:
Eo= 3V (125/125+150) - )200/250+300)
= 0V
The method looks OK except you seem to be using the wrong values for some of the components.
R1=100ohms, R2= 200ohms, R3= 250ohms, R4= 300ohms in the first post.
You are using 150 ohms for R2 and 200 ohms for R3.
  • · Replies 18 ·
