Solving a differential equation
zinDo
I want to solve Equation (1). w is a constant:
\begin{eqnarray} \text{Equation (1): }\frac{dx}{dt}=1+x^2w^2\end{eqnarray}
and I have been told that it is solved by (2):
\begin{eqnarray} \text{Equation (2): }x(t)=\frac{Ax(0)+B}{Cx(0)+D}\end{eqnarray}
Problem
I believe them, but before I keep solving it I want to know how one concludes that (1) is solved by (2). In order to get (2), should I integrate something like (3)? Is it some kind of ansatz that I should have known? ...
\begin{eqnarray} \text{Equation (3): }\frac{dx}{1+x^2w^2}=dt\end{eqnarray}
I don't know what is it that I should be looking for. Could I get a clue?
Thank you very much
This doesn't make sense to me, assuming that I'm interpreting your notation correctly. x(0) is just a constant, so what you have on the right side in equation 2 is just a constant (doesn't depend on t). It couldn't possibly be a solution to your diff. equation. x(t) = K, so dx/dt = 0, and 1 + x2w2 ≥ 1.
zinDo said:
Problem
I would use a trig substitution to integrate what you have on the left side just above.
##\int (\frac{1}{1+x^2}dx)=tan^{-1}(x) +C## , one of the basic integrals.
Eq. (2) is true if A, B, C, D are functions of t.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
