Solving a First Order Initial Value Problem
KevinD6
If y = y(t) is the solution of the initial value problem
y' + (2 t + 1) y = 2 cos(t)
y(0) = 2
What is y''(0)?
Since this is a first order linear, I started out by finding the integrating factor so I can find what y is, and then just take the second derivative of it, and then put it to 0.
IF = e^{ \int {2t + 1} } => IF = e^{t^2 + t}
Then, I end up with this equation, if we set IF = k.
(ky)' = k (2 cos(t))
From here, I don't think I can integrate that equation, so now I'm pretty much stuck. Is there a method I'm missing? Or could I find the value of the second derivative using the value of y at 0?
Any help is appreciated, thank you.
y(0) = 2
What is y''(0)?
Instead of trying to solve the original DE, try just differentiating it once and solving for ##y''## and see if you can get the answer from that.
Wow! I can't believe I didn't see that, haha, thanks man. Much appreciated.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
