Solving an ODE with power series method
SithsNGiggles
Solve ##(1-x)y''+y=0## at the point ##x_0=0##. Use this solution to find a solution to ##xy''+y=0## around the point ##x_0=1##.
##(1-x)y''+y=0##
##(x-1)y''=y##
##\displaystyle\sum_{k=2}^\infty a_k k (k-1)\left(x^{k+3}-x^{k+2}\right)=\displaystyle\sum_{k=0}^\infty a_k x^k##
I tried to find a recurrence relation for ##a_k##, but I keep getting 0 for all k. I realize that y = 0 is a solution, but I don't know how that would help me in the second part.
##(1-x)y''+y=0##
##(x-1)y''=y##
Compare the coefficients of xk: they have to be the same on both sides.
What do yo get for the constant term? What is the linear term?
ehild
Right, that's where my problem occurs:
##y''=\sum_{k=2}^\infty a_k k(k-1)\left(x^{k+3}-x^{k+2}\right)=a_2 (2\cdot1)\left(x^5-x^4\right)+a_3 (3\cdot2)\left(x^6-x^5\right)+a_4 (4\cdot3)\left(x^7-x^6\right)+\cdots##
##y=\sum_{k=0}^\infty a_k x^k=a_0 + a_1x + a_2x^2+ a_3x^3+a_4x^4+\cdots##
Matching up coefficients, I have
##a_0=0\\ a_1=0\\ a_2=0 \\ a_3=0\\
a_4=-(2\cdot1)a_2=0 \\ a_5=(2\cdot1)a_2-(3\cdot2)a_3=0\\ \text{and so on...}##
The second derivative of y is wrong. The correct equation is
\displaystyle\sum_{k=2}^\infty a_k k (k-1)\left(x^{k-2}-x^{k-1}\right)=\displaystyle\sum_{k=0}^\infty a_k x^k
ehild
Oh, right. I had (k + 2) on my mind for some reason. Thanks for pointing that out!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
