Solving Complex PDEs: Refs & Suggestions Needed
  • Thread starter Thread starter TheCanadian
    Complex Pdes
The discussion centers on solving a set of coupled partial differential equations (PDEs) with complex-valued solutions. The equations involve two independent variables, t and x, and parameters that are also complex. The individual seeks guidance on algorithms or software packages capable of handling complex PDEs, noting that existing solvers like FiPy are limited to real values. They express familiarity with basic complex analysis and Python, mentioning the Anaconda distribution as a useful tool for their work. The user has attempted to adapt existing Python resources but encounters issues with handling complex values, specifically receiving warnings about discarding imaginary parts during calculations. Suggestions for further reading or suitable packages to effectively solve these complex PDEs are requested.
TheCanadian
Hey! I've been trying to tackle this problem but I'm a little lost at the moment and any references or suggestions would be greatly appreciated. Essentially the problem boils down to solving (at least) 3 coupled partial differential equations with (at least) 2 independent variables. Now the solutions and parameters in these equations can be complex-valued and I've had trouble finding any good approaches or packages to help solve these equations. I know a bit of basic complex analysis although haven't taken a formal course in the subject yet, and am just struggling to figure out how I can build an algorithm or use an already known one to solve these complex PDEs. Here is an example of the type of equations I am considering:
## \frac {\partial A}{\partial t} = i (BC - B^*C^*) - \frac{A}{a} ##
## \frac{\partial B}{\partial t} = ibAC - \frac{B}{c} ##
## \frac{\partial C}{\partial x} = idB + e ##
where t and x are the independent variables (real numbers); a,b, c, d and e are parameters (complex); ## i = \sqrt{-1} ##; A, B, and C are the complex-valued states of the system that I am try to solve for. I've checked out a few different PDE solvers such as FiPy but they appear to only work with real values. I have begun looking into methods to solve complex PDEs such as above, but am still looking for methods better suited for my problem so that I have something to work with. If you have any material you'd suggest I look at or know of any packages well-suited to solve such equations, I'd be happy to look into them.
(I haven't put down any particular prefix for programming language since I don't mind learning something new and better suited for my problem. With that being said, I am most familiar with Python.)
Technology news on Phys.org
Here's one such reference using python:
http://ipython-books.github.io/featured-05/
If you don't have a python distro with all the necessary modules installed, I'd suggest getting the Anaconda distro where everything is integrated into one package. This link can help you get started using iPython and the notebook interface:
http://www.quant-econ.net/py/getting_started.html
Thank you for the response. I do have anaconda installed luckily. I've actually been using that first link and have tried to play around with it but am not quite too familiar with how to modify it for complex-value solutions and differentials. For example, using their exact code and simply multiplying the differential dt by the value they have to update the variable V and also multiplying this by ## i ##, I get the following prompt:
"ComplexWarning: Casting complex values to real discards the imaginary part
# Neumann conditions: derivatives at the edges"
But keeping the imaginary part would be important for the end.
You can always replace a single complex dependent variable with two real dependent variables (the real and imaginary parts of the original).
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
