Solving Differential Equations
mrmonkah
Solve the following: xdx = y^{2}dy
Fundamental theorem of calculus - thanks gabbagabbahey
\frac{dy}{dx}=\frac{x}{y^{2}}
\int\frac{dy}{dx} = \int\frac{x}{y^{2}}
=\frac{x^{2}}{2y^{2}}
So with the question, I've integrated both sides to find y^2 on the bottom, so should i rearrange to find y on the LHS and the x on the RHS?
mrmonkah said:
NA
Unless NA is your abbreviation for the fundamental theorem of calculus, you are mistaken :wink:
\stackrel{dy}{dx} = \stackrel{y^{2}}{x}
What happens if you integrate both sides of the equation x=y^2\frac{dy}{dx} with respect to x?
Hi gabbagabbahey,
Sorry, i am just getting to grips with the funky math features on the site, so my translation from paper to web isn't vry good. First of all i put in a monster mistake on the web, working on correcting this now.
Okay, more or less fixed now... thanks again Gabb
Right, so carrying on from my first post,
if i rearrange for y, i get:
y = \sqrt{\frac{x^{2}}{2}}
Your starting point is
x dx = y^2 dy
Right?
You can just integrate both sides right there. Start with that.
Ok, so if i integrate both sides i get:
\frac{x^{2}}{2} = \frac{y^{3}}{3}
and y = \sqrt[3]{\frac{3x^{2}}{2}}
Surely this isn't right is it? I don't recall coming across cubic roots in 'this particular' module. (I am simply looking for familiarity with the rest of the course)
You forgot the plus C.
Ahh okay fair enough Char.Limit, i am confused as to why re-arranging the initial equation (as i did earlier) yields such a different result?
It's mainly because you can't integrate x/y^2 dx, because y also depends on x.
So you can see why you couldn't integrate...
\int \frac{x}{y^2(x)} dx
Oh i see now. So with questions like these, i should generally keep all the y's on one side and the x's on the other? Ill attempt another question and post it to see if i have my head in the right place. Thank you Char.Limit, and as ever, you make a good point.
No problem. Glad I could help.
Solve the following: \frac{dy}{dx} = \frac{1 + y}{1 + x}
Re-arranging to get y terms and x terms on opposite sides:
\int\frac{dy}{1 + y} = \int\frac{dx}{1 + x}
Which gives:
ln(x + 1) = ln(y + 1)
and so:
y = x
Does this work out?
Close, but you still need to remember the +C.
Damn, every time. A habit i need to get used to.
No real problem. You just have to make sure you do it.
