Solving Differential Equations
The discussion revolves around a differential equation modeling memory retention in a psychology class, specifically the equation dN/dt = k(L-N), where N represents the number of objects remembered and L is the maximum number of objects. Participants are exploring how to solve this equation to find N as a function of time t.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are attempting to manipulate the differential equation to isolate N and dN, with some suggesting integration techniques. Questions arise about the proper handling of terms and the integration process.
There is a mix of approaches being discussed, including suggestions for u-substitution and integration techniques. Some participants are questioning the clarity of initial conditions and boundary values, while others are providing feedback on the manipulation of the equation.
Participants note potential ambiguities in the problem statement regarding initial conditions, specifically whether N=0 at t=0 or if it should start from a different value. There is also discussion about the maximum number of objects remembered as time approaches infinity.
Northbysouth
A psychology class is studying memory. Several objects are uncovered to view for a given amount of minutes and then covered again. At most 150 objects can be viewed and remembered. The class found that after 10 minutes the average student could remember 25 objects. The differential equation that models this study is given by
dN/dt = k(L-N)
Solve this differential equation to find an equation that will give the number of objects remembered at any time t.
I'm a little unsure of what I'm doing, so some feedback would be great.
dN/dt = k(L-N)
dN = (kL - kN)dt
So, I think I need to move the N on the right hand side to the left, but I'm not sure how to do this, as every action I take keeps other prevents me from isolating N and dN on the left hand side.
Can I leave the N on the right hand side and integrate the left with respect to dN and the right with respect to dt?
dN/dt = k(L-N)
dN/dt = k(L-N)
dN = (kL - kN)dt
Move all of the N's to one side. dN/(k*(L-N))=dt. Now integrate both sides.
Assuming K and L are constants.
How about dividing by (L-N) on both sides from dN/dt = k(L-N) instead of distributing the K? This equation is separable.
I hadn't considered moving t to one side by itself. Thanks.
So, I should end up with:
t = 1/k*ln(L-N)
t = 1/k*ln(L-N)
Almost. I'd write that (1/k)*ln(L-N). But I think you missed a '-' sign and you should put a +C someplace.
dN/dt = k(L-N)
dN/dt = k(L-N)
dN = (kL - kN)dt
Even easier: notice that since L is a constant we have dL/dt = 0, so dN/dt = d(N-L)/dt. Therefore, if x = N-L you have dx/dt = -kx.
When I spoke with my professor she informed me that I needed to use a u-substitution in order to integrate.
∫dN/(L-N) = ∫k dt
u = L-N
du = -dN
dN = -du
∫-du/u = ∫k dt
-ln(u) = kt + C
-ln(L-N) = ekt + C
N = ekt + C+ L
Then using the information given, I think that at t=0 N=150
150 = eC + L
So I have L = 150 - eC
I also know that at t=10 that N=25
25 = e10k +C + L
I have three unknowns but only two equations. Unless I'm missing something, I don't think it's possible for me to solve for L, C and k.
All suggestions are appreciated.
I think the sign in front of k got messed up. When you've got -ln(L-N)=kt+C, it's better to multiply both sides by (-1) first so you've got ln(L-N)=(-kt+C). Now exponentiate. And when you've got something like e^(-kt+C) it's usually easier to write it as e^(-kt)*e^C. And since C is a constant, e^C is just another constant, so write it as just plain C. I.e. Ce^(-kt).
On the initial value you thing, the statement of the question isn't crystal clear, but I think what they mean is at t=0, the student is just starting and hasn't memorized anything yet. So at t=0, N=0. At t=10, N=25. Finally for very large values of t the student should max out at 150 objects, so as t->infinity N->150. You do have three boundary conditions.
  • · Replies 17 ·
