Solving equations but getting an identity - what mistakes were made?
  • Context: High School
  • Thread starter Thread starter farfromdaijoubu
The discussion revolves around the implications of arriving at an identity when solving algebraic equations, particularly in the context of projectile motion. Participants explore the meaning of such outcomes, the types of equations involved, and the potential mistakes that could lead to these results.
  • One participant notes that ending up with an identity, such as 0=0, may indicate that the variable is a degree of freedom and can take any value, but it could also suggest a mistake in the process, such as misusing the statement to be shown or making typographical errors.
  • Another participant emphasizes that an identity is a true statement and implies that the solver did not reach the intended conclusion, mentioning that certain operations, like integration by parts, can lead to identities.
  • A participant categorizes equations into three types: conditional equations, identities, and contradictions, providing examples for each type to clarify their distinctions.
  • It is suggested that arriving at an identity may indicate that the starting equation was already an identity, and a request is made for a specific example to further illustrate the point.
  • One participant mentions that in the context of a system of equations, reaching an identity often means that the equations are not independent and may be redundant.
Participants express various viewpoints on the implications of obtaining an identity, with no consensus reached on the specific mistakes that may lead to such outcomes. The discussion remains unresolved regarding the exact nature of the errors involved.
Participants highlight the importance of understanding the types of equations and the conditions under which identities arise, but the discussion does not resolve the specific assumptions or limitations that may affect their claims.
farfromdaijoubu
TL;DR
What are the mistakes made when you try to solve equations for some variable/s but end up with an identity?
This might be a bit vague but when solving algebra equations, what does it 'mean', or what mistakes does it imply if you end up with both sides of the equation being the same thing and getting nowhere? For example, you want to solve a system for x, but the x's end up cancelling and you get 0=0.
For context I was just doing some basic projectile motion stuff - wanted to find minimum speed at which a ball thrown at a given angle would always collide with another dropped at the same instant but ended up constant = constant.
But I've run into the same issue many times before and never properly learnt what I was doing wrong whenever it happened.
Mathematics news on Phys.org
It usually means that your variable is actually a degree of freedom and can be set to anything. However, it could also mean that you made a mistake, like using the statement that you want to show, or simply typos. It depends on the case.
  • Agree
farfromdaijoubu said:
TL;DR Summary: What are the mistakes made when you try to solve equations for some variable/s but end up with an identity?
You don't need to do anything wrong to get an identity. An identity is a true statement. It just means that you didn't end up where you wanted to.
For example, if you use integration by parts twice, changing the roles of the functions, you tend to end up with an identity.
There are three kinds of equations: conditional equations, identities, and contradictions.
A conditional equation is one in which the variable can take on only a limited number of values for the equation to be a true statement. For example, ##x^2 - 3x + 2 = 0##. This equation is a true statement only for x = 1 or x = 2.
An identity is an equation that is a true statement for all values of the variable. For example, ##x^2 - 3x + 2 = (x -1)(x - 2)##. Any real value (or even a complex value) can be substituted for x here and the resulting equation will be a true statement.
A contradiction is an equation that can never be true, no matter which value the variable takes on. For example, ##x = x + 1## is never true for any value.
It seems to me that you are starting from an equation that is an identity and applying operations to both sides to eventually get to 0 = 0. Can you give me a specific example of an equation that you're talking about?
For a system of equations this usually means that the equations are not independent of each other (redundant).
