Solving Flotation Problem: Estimate a Polar Bear's Mass
  • Thread starter Thread starter WhackyWookie
To estimate the mass of a polar bear partially supported by a slab of ice, the discussion emphasizes using the principles of buoyancy and equilibrium. The ice has a specific gravity of 0.917 and is submerged halfway, while the bear has 70% of its volume and weight out of the water. Participants suggest calculating the volume of submerged ice and setting up an equation where the net force equals zero, incorporating the buoyant forces and weights involved. Despite following this method, one user consistently arrives at a mass of 592.9 kg, which contradicts the expected answer of 790 kg found in a reference book. The conversation highlights the importance of showing work and ensuring unit accuracy in calculations.
WhackyWookie
The problem is:
A polar bear partially supports herself by pulling part of her body out of the water onto a rectangular slab of ice. The ice (with specific gravity of 0.917) sinks down so that only half of what was once exposed now is exposed, and the bear has 70% of her volume and weight out of the water. Estimate the bear's mass, assuming that the total volume of ice is 10 m^3, and the bear's specific gravity is 1.0.
I have tried to solve it using the equivalence of the ratios between the volume of displaced water and volume of object and density of object and density of fluid, but have been consistently getting wrong answers. Any help is appreciated.
WhackyWookie said:
The problem is:
As a general approach, do it like this: You can find out what volume of ice is originally submerged (without the bear on it). Now, set up an equation where the net force is zero. The forces acting on the system would be the buoyant force on 30% of the bear, the buoyant force on the ice (and you should be able to figure out what volume of ice is in the water based on the previous calculation, and the fact that another 50% is submerged), the weight of the ice, and the weight of the bear. Solve for the weight of the bear, and thus determine the mass. Also, you can express the volume of the bear in terms of its specific gravity and its mass. So you'll have an "m" variable in two places, but still only one unknown and one equation, meaning you can still solve it.
thnx for ur explanation, but the answer I got using ur method is the same as I got before (592.9 kg), which is inconsistent with the 790 kg answer listed on the back of the book.
Perhaps you should show your work, and make sure your units are correct.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
