Solving for an unknown in differential equation solution
Ewan_C
(1): \frac{d^{2}y}{dx^{2}} + 4\frac{dy}{dx} + 20y = 10e^{-2x}\cos (rx), y(0) = 1, y'(0) = 0
Show that there is precisely one value for r for which e^{2x}y(x) can become arbitrarily large where y(x) is a solution of (1)
I used Maple to solve the DE and found a particular solution y(x).
e^{2x}y(x) = -\frac{10(-\cos 4x + \cos rx)}{-16+r^2}
When r tends to 4 or -4 then e^{2x}y(x) can become arbitrarily large, but this doesn't seem to me like it satisfies the question - it's not "precisely one value" and it's not an exact value of r. I graphed e^{2x}y(x) and can't see anywhere else it can become arbitrarily large. I feel like I'm missing something, can anyone point me in the right direction? Cheers.
Hi Ewan_C! :wink:
Sorry, but this is what happens when you take short-cuts …
there is a solution for r = ±4, but it doesn't involve cos4x.
Start again, put y = ze-2x, get the differential equation for z, put r = ±4, and look for another particular solution. :smile:
Hi Tim, thanks for the response.
So you mean that I should substitute y(x) = z(x)*e-2x into the original DE and solve it for z? Now I get it, that's what they meant from the start - I took "where y(x) is a solution of (1)" to mean a particular solution rather than the general solution.
We haven't yet been taught how to solve DEs with non-constant coefficients, so I used Maple again to solve the DE. I used the following commands:
DE := diff(exp(-2*x)*y(x),x,x)+4*diff(exp(-2*x)*y(x),x)+20*exp(-2*x)*y(x) =10*exp(-2*x)*cos(r*x);
DE_hom := diff(exp(-2*x)*y(x),x,x)+4*diff(exp(-2*x)*y(x),x)+20*exp(-2*x)*y(x) = 0;
dsolve({DE,y(0)=1,D(y)(0)=0},y(x)) - dsolve({DE_hom,y(0)=1,D(y)(0)=0},y(x));
I didn't substitute y(x)=z(x)e-2x as it made Maple get angry with me - my Maple skills aren't too brilliant! I think what I did is equivalent though?
Am I correct in thinking that if you take the general solution of the DE and subtract the general solution of the corresponding homogeneous DE, the result is a particular solution of the DE?
This still gave me a particular solution with a cos(4x) term. I don't really know what's going on with this DE as I can't solve it by hand. Maybe the best next step would be to spend some time on the internet learning how solve DEs with non-constant coefficients?
Sorry, Ewan_C, I've no idea what Maple is or how it works. :redface:
Surely you can work out what dy/dx and d2y/dx2 are in terms of dz/dx and d2z/dx2 without a calculator? :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
