Solving for Point D: How to Find the Intersection of Two Linear Equations
  • Thread starter Thread starter hyde2042
    Point
The problem involves finding the intersection point of two linear equations represented by constraints in a graphical context. The subject area includes linear equations and systems of equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the constraints derived from the equations and attempt to graphically represent them. There is an exploration of solving the system of equations to find the intersection point, with some participants questioning their calculations and the correctness of their results.
Some participants have provided guidance on potential errors in calculations, while others are sharing their attempts and results. There is an ongoing exploration of the problem without a clear consensus on the correct solution.
Participants note discrepancies between their results and the expected answer from a textbook, indicating possible misunderstandings or miscalculations in the setup or solving process.
hyde2042
The problem:
[2] http://i.imgur.com/C5VwZ.png
So I got the constraints to be
1.x+y(less than or equal to) 275
2.225x+250y (less than or equal to) 63,000
3. x and y (Greater than) 0
So if the line from point A is extrapolated, then where it hits the x-axis would be constraint 2 and point C is constraint 1.
The graph I ended up with:
[1] http://i.imgur.com/9jJYt.png
hyde2042 said:
The problem:
Point D is where the line x + y = 275 intersects with the line 225x + 250y = 63000. This is a simple matter of solving a system of two equations in two unknowns.
The problem you posted in your first link seems to have nothing to do with what you're doing here.
Whoops. Sorry about the wrong post.
When I set the two equal to each other. -x + 275 = (225/250)x + (63000/250) I'm getting the incorrect answer.
The book says it should be (230, 45)
I keep getting (12.1, 262.9)
You have a sign wrong in the right side. Solving the second equation for y gives y = -(225/250)x + 63000.
I get the right answer.
  • · Replies 22 ·
