Solving for potential energy after time t.
The discussion revolves around calculating the potential energy of a stone dropped from a height of 80 meters after a certain time, t. The problem involves concepts from kinematics and gravitational potential energy.
  • Participants explore the relationship between potential energy, height, and time, questioning how to define height (h) in the context of the stone's fall. There is an attempt to relate potential energy to the distance fallen and the remaining height.
Some participants have provided insights into the relationship between potential energy and height, while others are questioning the definitions of variables and the conditions under which potential energy is zero or maximum. The discussion reflects a mix of interpretations and attempts to clarify the concepts involved.
There is an ongoing exploration of the definitions of height and distance fallen, as well as the implications of the initial conditions of the problem. Participants are considering the effects of gravitational acceleration on the potential energy calculations.
blipped
A stone of mass 0.2kg is dropped from the top of a building 80m high. After t seconds it has fallen x meters and has a velocity of v. What is the potential energy of the stone t seconds later
The answer is 2(80 - x) = 160 - 10t^2
Using suvat: s = ut + (1/2)at^2
I started with PE = mgh
PE = 0.2 * 10 * h
PE = 2h
Then I figured h = (1/2)*10*t^2
or h = 5t^2
So now I have
PE = 10t^2
Not sure if I'm headed in the right direction or not.
blipped said:
So now I have
PE = 10t^2
That gives PE=0 at the instant of dropping. Where should PE be 0 and where should it be maximum?
It is coming downwards.
blipped said:
s = ut + (1/2)at^2
What is s?
blipped said:
PE = mgh
What is h?
Are they both same in this problem?
I got it, or at least I understand the answer now. 80 - (80 - x) gives the remaining distance with regards to x, and this equal to the same measurement given (1/2)(g)t^2. Set them equal and shuffle around a bit. Thanks
Right.
x=80-h.
  • · Replies 20 ·
14K
