Solving for Simple Harmonic Motion Phase Angle
18 replies · 3K views
unhip_crayon
A block, attached to a spring, moves in Simple Harmonic Motion on a horizontal frictionless
table. The displacement from equilibrium is given by x = xm cos (ω t + φ ) where x is positive to
the right of the equilibrium position. The frequency of the motion is 3.10 Hz and the amplitude
is 15.0 cm. At t = 0.00 s, the velocity of the block is 2.70 m/s to the left and the position is to the
left of the equilibrium position.
Calculate the phase angle, φ.
Answer: 1.96 Rad
I have no Idea what I'm doing wrong. I am almost certain its a stupid mistake
xm=0.15m
w=2[tex]\pi[/tex]f
w=19.478
V=wx
2.7=19.478x
x=0.139
t=0
now I just plugged and chugged it all into x = xm cos (ω t + φ )
but i got the wrong answer...help please
Check your expression for V (I'm guess that is the velocity). Remember that
[tex]V={dx \over {dt}}[/tex]
I don't think that works...
V=dx/dt = x(t)=0.15cos[tex]\phi[/tex]
x'(t)=-0.15sin[tex]\phi[/tex]
x'(t)=accel.=(xm)(w^2)
=(0.15)(19.478)
=56.9m/s^2
sin[tex]\phi[/tex]=56.9/.15 ---> does not work
Am I doing something wrong?
Take the derivative before plugging in t=0. And remember that you're differentiating with respect to t and not phi.
[tex]v={dx \over dt}=-\omega A sin(\omega t + \phi)[/tex]
This is where you want to put your givens.
I think the formulas you are using, v=w xm and a=w^2 xm are for the MAXIMUM velocity and acceleration.
correct...is that a problem?
What makes you think the velocity is at a maximum? What is the velocity as a function of time (hint: see post #4)?
If you plug 2.7 m/s into the formula for the maximum velocity it is a mistake, because 2.7 m/s is not the maximum velocity, it is just the initial velocity.
You should be able to put v=-2.7, t=0, A=0.15 and w=19.5 into the formula I gave you, then solve for phi.
Also, make sure that your calculator is set to radian mode.
That formulae will not yield the correct answer using a calculator. He will have to make sure the result is in the correct quadrant.
Hmm. This is not good:
The reason is that you spoon-fed the OP a formula, and he/she will be able to "plug in the numbers", get a result, and not have the foggiest idea why things work that way. The OP is missing something very basic here. In retrospect, it would have been much better to press the OP to come up with post #4 rather than give it out.
I tried that but it doesn't give me the right answer...1.18 rad, I need 1.96 rad
Sorry DH. You're right. I should be more careful and keep in mind what the purpose of this forum is. I just get so excited when I actually know how to help someone, I get carried away. And in this case I wasn't even right. I'll watch myself in the future. Thanks.
That one you'll have to work out unhip_crayon.
And DH..I was wondering what OP means?
OP=Original Poster
unhip_crayon, Can you see how Pacopag derived the velocity equation? You should be able to derive this yourself. Give it a shot. Understanding how velocity varies with time is central to this problem.
I understand how pacopag derived the velocity equation, the thing is, I haven't slept in 20 hrs, so I'm exhausted, I'm going to bed now. Thanks for the help guys. I''ll email my prof to double check that answer.
You should have got -1.18 radians by calculator rather than 1.18.
The sine function hits all non-zero values twice over any interval of length 2*pi. The inverse sine function has a range of pi, not 2*pi. When you use the inverse sine to calculate an angle you have to make sure that the value is in the correct quadrant. You need some other information to do this, but the problem has that information. You were told the initial velocity (it has a sign; I don't think you used that info) and enough about the position (left of the origin) to resolve the angle.
