Solving for Theta, wolfram doesn't give anything useful
  • Thread starter Thread starter physstudent.4
    Theta
physstudent.4
I need to write a function of theta in terms of a particular variable. I just can't seem to figure it out; the only solution I can come up with is when the aforementioned variable is equal to 0 or 1. I'm using Q to denote theta, and b is the variable.
sin^3(Q)/cos(Q)=b^2
Any and all trig identities.
I've used sin^2(x)+cos^(x)=1, sin(2x)=2sin(x)cos(x), I haven't stumbled into any work that led me to use other identities!
Around 5 pages of scratch work, all for naught.
Any relevant trig identities I might be missing would be nice to know, if anyone figures this out soon! Thanks!
sin^3(Q)/cos(Q)=b^2
sin3(θ)/cos(θ) = 1/(cot(θ)csc2(θ)) = 1/(cot(θ)+cot3(θ))
but I don't think this will help all that much.
You can reduce it to a polynomial equation. Square both sides. Replace cos(Q)^2 by 1-sin(Q)^2. Now let P=sin(Q)^2. You'll get a cubic equation in P. You CAN solve a cubic exactly, but the solutions are so complicated as to be almost useless. You will have a little advantage here because there is no P^2 term. But it's still pretty complicated. Stuff like this is usually handled numerically, not analytically.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
