Engineering Solving for voltage and current on an RC circuit
- Thread starter DODGEVIPER13
- Start date
- Tags
- Circuit Current Rc Rc circuit Voltage
The discussion revolves around solving for voltage and current in an RC circuit with a switch that has three positions, creating different circuit configurations. Participants express confusion about the switch's behavior and the resulting circuit analysis, particularly regarding the time spent in each position and the impact on voltage and current calculations. Key calculations include determining the current through a 40Ω resistor and the voltage across a capacitor, with the eventual steady-state current identified as 0.125A as time approaches infinity. The final expressions for current are clarified, with participants concluding that the current is 0.750A for t<0 and 0.125 + 0.750e^(-t/20)A for t>0. The ambiguity in the problem statement is noted as a potential flaw in the question.
gneill
Mentor
- 20,989
- 2,934
The problem statement is a bit ambiguous since the switch in the circuit appears to have three separate "positions" as it moves from a to b. Each position creates a different network. Since no information is given about the length of time the switch remains in each position as it makes the transition, it's not possible to give a definitive answer for the voltage or current functions with respect to time. Or are we to assume that the switch begins in the center position for time t ≤ 0, and moves to position b at time t = 0?
DODGEVIPER13
- 668
Yah I think it goes from a at t<0 and moves to b at t=0
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:Yah I think it goes from a at t<0 and moves to b at t=0
So you're making the assumption that the switch moves from position a to position b instantaneously, spending no time in the region where the contacts overlap.
In that case, your workings for the capacitor voltage w.r.t. time look okay. But you should take another look at the current through the 40Ω resistor; how does the potential across that resistor vary for time t > 0?
DODGEVIPER13
- 668
at t>0 it is strictly at position b right so that would eliminate the 40 v source and leave me with just the 30 volt source going over the 120 ohm and 40 ohm resistors right?
DODGEVIPER13
- 668
which would give me i=30/160=.1875A hmmmm I got that for the first part to the current at t=0? So I know my logic is wrong
gneill
Mentor
- 20,989
- 2,934
At switch position b, there's more to the circuit than just the 30V source and the 120 and 40 Ohm resistors.
DODGEVIPER13
- 668
the 60 ohm resistor and capacitor is as well right?
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:the 60 ohm resistor and capacitor is as well right?
Right.
DODGEVIPER13
- 668
ok so are the 40 ohm and 60 ohm resistors in parallel with each other and then the 120 ohm one is in series with that giving a total R=144 ohm so therefore I= 30/144=.208 A??
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:ok so are the 40 ohm and 60 ohm resistors in parallel with each other and then the 120 ohm one is in series with that giving a total R=144 ohm so therefore I= 30/144=.208 A??
Well, your figuring of total resistance may be correct, but you're looking for the current through the 40Ω resistor alone...
DODGEVIPER13
- 668
could I use my current divider as I did earlier multiplied by the total current in the b portion only so .208(60/100)=.1248A and the current through the 40 ohm resistor is 30/40=.75A then using my charascteristic equation I get .1248+.6252e^(-t/20).
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:could I use my current divider as I did earlier multiplied by the total current in the b portion only so .208(60/100)=.1248A and the current through the 40 ohm resistor is 30/40=.75A then using my charascteristic equation I get .1248+.6252e^(-t/20).
Just scanning your text I can't tell where the numbers are coming from. But if you look at the schematic you can see that the 40Ω resistor parallels the capacitor when the switch is in the (b) position. So if you already have the expression for the capacitor voltage with respect to time, you can trivially write the expression for the resistor current...
DODGEVIPER13
- 668
so is the capacitor voltage 30 volts because 40(60/(60+20))=30 V or should I use an equation to find for the capacitor voltage?
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:so is the capacitor voltage 30 volts because 40(60/(60+20))=30 V or should I use an equation to find for the capacitor voltage?
? The capacitor voltage will start at some initial value at time t=0 and will evolve to some other value as time progresses. You worked out the initial value for Vc before (you found 30V), and you should be able to find the eventual value (with the switch in the b position) for t >> 0. But you did all this in the workings that you posted previously, right?
DODGEVIPER13
- 668
at t>0 the eventual value would be this 5+25e^(-t/20) you said I already calculated it so I can only assume this is what you are referring to?
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:at t>0 the eventual value would be this 5+25e^(-t/20) you said I already calculated it so I can only assume this is what you are referring to?
The EVENTUAL value is 5V. That's when t → ∞. What you have written, 5+25e^(-t/20), is the function that describes the value Vc(t) for all t > 0.
So, if you have the function for Vc for t > 0, you should be able to write the function for the current i(t) as well, since the same potential Vc(t) appears across the 40Ω resistor.
DODGEVIPER13
- 668
ok well as t approaches infinity I have Vc= 5 V so if this is true 5 volts is what goes across the 40 ohm resistor. therefore the amperage across the 40 ohm is I=5/40=.125A.
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:ok well as t approaches infinity I have Vc= 5 V so if this is true 5 volts is what goes across the 40 ohm resistor. therefore the amperage across the 40 ohm is I=5/40=.125A.
Yes, that would be the final current...
Does the solution require the final current or an expression for the current over time, i(t)?
DODGEVIPER13
- 668
Hmmm it calls for an expression so I know it is of the form I(t)= .125+Ae^(-t/20)
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:Hmmm it calls for an expression so I know it is of the form I(t)= .125+Ae^(-t/20)
Sure. But you ALREADY KNOW the expression for Vc(t), and the resistor parallels the capacitor... so Vc(t) is across the resistor...
DODGEVIPER13
- 668
oh so are you saying that I(t)=Vc(t)/40 which would give i(t)= .125+.625e^(-t/20)
DODGEVIPER13
- 668
am I getting warmer?
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:oh so are you saying that I(t)=Vc(t)/40 which would give i(t)= .125+.625e^(-t/20)
Yes (But be sure to always include the units in your results).
DODGEVIPER13
- 668
ok so the answer should be:
i(t)=.1875A for t<0
i(t)=.125+.625e^(-t/20)A for t>0
i(t)=.1875A for t<0
gneill
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:ok so the answer should be:
i(t)=.1875A for t<0
Sure.
(Although I still think that the question is flawed to the ambiguity introduced by the switch design in the schematic)
DODGEVIPER13
- 668
oh wait nvm I did something wrong I think it should be :
i(t)=.750A for t<0
i(t)=.125+.750e^(-t/20)A for t>0
i(t)=.750A for t<0
DODGEVIPER13
- 668
never mind again heh I was correct earlier
- · Replies 8 ·
- Replies
- 8
- Views
- 2K
- · Replies 12 ·
- Replies
- 12
- Views
- 2K
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
Engineering
Solve Superposition Theorem for R1, R2 Circuit
- · Replies 18 ·
- Replies
- 18
- Views
- 3K
Engineering
Calculating the voltage at a certain Resistor
- · Replies 3 ·
- Replies
- 3
- Views
- 2K
Engineering
Transform question about this circuit
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- Replies
- 1
- Views
- 2K
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
Engineering
AC Circuit Phasors: Find I1, I2, I3
- · Replies 26 ·
- Replies
- 26
- Views
- 3K
- · Replies 34 ·
- Replies
- 34
- Views
- 5K
