MHB Solving $\frac{\sin(x-1)}{x^2+x-2}$ Without L'Hopital's Rule
  • Thread starter Thread starter Petrus
    L'hopital's rule
Petrus
Hello,
I would like to solve this without lhopitals rule aswel( i succed get the answer 1/3 with lhopitals rule but do not go well without)
$$\lim_{x \to 1}\frac{\sin(x-1)}{x^2+x-2}$$
Any tips i would like to have
Re: Trig limit
Hint , try first factorizing the denominator , and use $$\lim_{x\to 0 }\frac{\sin x}{x}=1$$.
Re: Trig limit
Hello ZaidAlyafey,
I can factor out $x(x+1-2/x)$ but How can I use that..? My lim goes to 1 but to Apply that law the lim goes to 0. I se that it Will be zero on sin(1-1) but not on denominator
Your factorization of the denominator is not what Zaid intended. Please see:
http://www.mathhelpboards.com/f49/factoring-quadratics-3396/
for a tutorial on how to factor quadratics. You should find that the denominator factors nicely into two linear factors, one of which is $(x-1)$.
Let us know what you find. :D
Hello,
i keep doing bad move.. Don't get me wrong i never thought about that x-1... $(x-1)(x+2)$
Don't get me wrong i was not thinking this ohh well i learn by My misstake!
When solving limits of the form 0/0 , you should try to eliminate the term which makes the denominator and numerator zero , like for this example the term is (x-1) so we should foresee a way to expose it then cancel it ...
Petrus said:
Hello,
Hello Petrus,
Part of learning is making mistakes, so don't get discouraged by it. It is through our mistakes that we learn the most, as you wisely pointed out.
Can you now state the given limit the product of two limits, both of which you can evaluate?
MarkFL said:
Hello Petrus,
Well after factour that and simplify i get $$\lim_{x \to 1}\frac{1}{x+2}$$ = 1/3
You can use LH to verify your answer ...
What does LH means?
Petrus said:
What does LH means?
Oh ,sorry , I thought that was ambiguous , I meant the L'Hopitals rule ...
This is more what I had in mind:
$$\lim_{x\to1}\frac{\sin(x-1)}{x^2+x-2}=\lim_{x\to1} \frac{\sin(x-1)}{(x-1)(x+2)}=\lim_{x\to1} \frac{\sin(x-1)}{x-1}\cdot\lim_{x\to1}\frac{1}{x+2}=1 \cdot\frac{1}{3}=\frac{1}{3}$$
But, as long as you understand the steps involved, this is what is ultimately most important. :D
We can as well use the substitution x-1=t then we have :
$$\lim_{t\to 0}\frac{\sin(t)}{t(t+3)}=\frac{\lim_{\,t\to 0}\frac{\sin(t)}{t}}{3}=\frac{1}{3}$$
MarkFL said:
This is what more I had in mind:
Hello Mark,
i wanted to ask if its wrong to define $$\lim_{x\to1} \frac{\sin(x-1)}{(x-1)(x+2)}=\lim_{x\to1} \frac{1}{x+2}$$ what i mean is that on paper I would draw a line on $\sin(x-1)$ and $x-1$ that means they would take out each?
You may casually cancel the two, as long as you are mindful that you are not dividing them out in the traditional sense of reducing a fraction, but you are only doing so in light of the result:
$$\lim_{\theta\to0}\frac{\sin(\theta)}{\theta}=1$$
On an exam, I would highly recommend making a note of this to let your professor know exactly what you are doing, otherwise you may have points deducted.
