Solving Frictionless Slides: No Mass Required!
  • Thread starter Thread starter runningirl
    Frictionless Mass
The discussion focuses on calculating the speed of a slider at the bottom of a frictionless water slide inclined at 25 degrees over a length of 30 meters. Participants explore different methods to find acceleration, including using F = ma and conservation of energy principles. It is emphasized that mass is irrelevant in these calculations because it cancels out in the equations. Various acceleration values are proposed, with some confusion over the correct approach and results. Ultimately, the conversation highlights the importance of understanding the physics behind the problem rather than just plugging in numbers.
runningirl
A water slide can be though of as being frictionless. Let's say a slider starts from rest and goes down a slide that is 30 m long and is set at a 25 degree incline.
a) determine the speed of the slider at the bottom of the slide.
b) Explain why you don't need to know the mass of the slider.
f=ma
sin(25)*30=a
a=12.7 m/s/s.
i don't know if that's right.
would i not need the mass for the acceleration?
hi runningirl! :smile:
runningirl said:
sin(25)*30=a
a=12.7 m/s/s.
you can solve this either by F = ma or by conservation of energy
i assume you want to use F = ma (in the direction of the slope) …
ok, if the mass is m, then what is F? :smile:
As the slide is frictionless, this is a fairly simple constant-acceleration problem. The only acceleration is in the y-direction, you can use a constant-acceleration equation to determine the downward velocity. Since you know the angle, you can then calculate/convert v_y to v.
uh... I'm not quite sure if i can find the acceleration since i have two unknown variables with f=ma.
why are you using distance?
but then i'll have two unknowns.
write it out anyway … something should cancel
uh...
f=m(12.7m/s/s)?
where does the 12.7 come from? :confused:
start from the beginning
then it would just be f=ma because i don't have a force, mass, or acceleration.
i think i figured it out.
i did ma=m(9.8)(sin25)
a=4.14
but i did it another way and got a different answer...
m(h)=.5(ma^2)
30/sin(25)=.5ma^2
a=5.96 m/s/s.
(just got up :zzz: …)
a=4.14
yes that's completely correct :smile:
(an alternative way is simply to say that the acceleration is the component of the gravitaitonal acceleration in the direction of the slope, ie 9.8cos65°)
m(h)=.5(ma^2)
30/sin(25)=.5ma^2
a=5.96 m/s/s.
i think you're thinking of conservation of energy …
mgh = .5mv2
(i can't think of any formulas with a2 in them)
