Solving integral using residue theorem
arpitm08
Find the value of ∫ x^2/(((x^2 + 4)^2)(x^2+9)) dx. With the limits from 0 to infinity.
I know that this is an even function so we can calculate the value of the integral from -∞ to ∞ and just divide by 2. The upper half plane singularities are 3i and 2i and 2i. I calculated the residue for 3i, but couldn't figure out a way to calculate it for 2i. I tried to take the derivate of the denominator, but if you plug in 2i into that, you would get 0. I tried other ways, but they only resulted in negative answers. Is there a way that I'm not thinking of to find the residue at 2i? Thanks for any help.
The pole at ##z = 2i## is not a simple pole, so you have to use the residue formula for nth order poles. If a function f(z) has a pole of order n at z0, then
$$Res(f,z_0) = \lim_{z\rightarrow z_0} \frac{1}{(n-1)!} \frac{d^{n-1}}{dz^{n-1}}\left[(z-z_0)^n f(z) \right]$$
It's a 2nd order pole. I took the derivative of h(x) = f(x)*(x-2i)^2. Then h(2i)=-13 * i / 200. Is that right?
Yes, it is. Well done!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
