How can I solve this limit algebraically without using the conjugate method?
  • Thread starter Schrodinger's Cat
  • Tags
    Limits
I have trouble thinking up stuff like that on my own...And that's why I teach math and don't do research in it.In summary, the conversation revolved around solving the limit as x approaches 1 of (x^.5-x^2)/(1-x^.5) algebraically. The individual had tried multiplying by the conjugate 1+x^.5 but was unable to cancel out the 1-x term in the denominator. Others suggested using long division or rewriting the numerator in terms of x^1.5. Eventually, the solution was found by using long division to get a remainder of (x^.5-x^1.5)/1-x, which could then be simplified to x^1.5(
Schrodinger's Cat
35
I'm trying to solve this limit algebraically
limit as x approaches 1 (x^.5-x^2)/(1-x^.5).
I tried multiplying by the conjugate 1+x^.5 but that left the denominator with 1-x and I was unable to cancel that out.
Can anyone help me out?
Well, can you show what you got when you tried that?
Sure.
I got (x^.5+x-x^2-x^(5/2))/(1-x).
I can't figure out how to factor the top so as to cancel out the 1-x part.
Well, you can always do long-division to see if there's anything left-over. Or, which amounts to the same thing, rewrite your numerator with tricks like:
-x^2.5 = (1-x) x^1.5 - x^1.5
(Actually, you could have done long division right from the beginning, without bothering with the conjugate -- I wonder why this isn't often taught?)
Hrm. Maybe the person who wrote the problem expected you to split the numerator into parts that do and do not have fractional powers of x. i.e. as:
x^.5 (1 - x^2) + (x - x^2)
I'm not sure if I prefer this, or the division method I mentioned.
p.s. you meant x^(5/2) not x^5/2.
I tried getting it into other formats such as x^.5-x^2/1-x^.5 but it didn't work out too well.
How exactly would that work out (I'm kinda lost here)? I'm just trying to rationalize the function so as to find the limit for it.
(I've added a bit more to my previous post)
Well, division here works just like ordinary division
Code:
      x^1.5 + x
1-x | x^.5 + x - x^2 - x^2.5
      x^1.5 - x^2.5
      x^.5 + x - x^1.5 - x^2
      x - x^2
      x^.5 - x^1.5
I've done the first two steps for you -- first, I chose x^1.5, because if I multiply the divisor by x^1.5, I can cancel out the biggest term in the dividend after subtracting.
(I've decided to have high powers of x be the "biggest" term -- you can do the opposite if you prefer)
How did you get that?
Not exactly sure how you got that as well...
So, what about the remainder resulting from the long division? You're saying that it'll factor into ((1-x)(x^1.5+x))/(1-x). The 1-x will cancel out leaving x^1.5 +x?
Yeah, my mistake. Not used to typing it all out on a keyboard.:tongue2:
Edited.
Try multiplying it out! This is a very, very useful trick -- you should learn it!
Again, try multiplying it out!
(Or did you mean "how did I think of it"?)
Wait, I see how you got those two parts though I'm not sure how that would help me out though.:uhh:
Starting from the original equation, it can be solved with partial fractions to be:
x^1.5-1+(1-x^1.5)/(1-x^0.5)
=x^1.5-1+(1-x^0.5)*(1+x^0.5+x)/(1-x^0.5)
Limit as x -> 1 is therefore 3.
If you stop there, then yes. (Except you swapped the quotient and the remainder):
(x^.5 + x - x^2 - x^2.5) / (1-x)
= (x^1.5 + x) + (x^.5 - x^1.5) / (1-x)
but the division isn't finished -- you can get a better remainder!
Yeah, I see now but I don't see how that will help me factor the top though...
I'm suggesting that, if you wanted to do it this way, to try this trick a few times, and see if you wind up with something useful! (This is what I first did)
Stare at it for a while. Maybe putting it back into conext will help: you want the limit of
[tex]
\frac{\sqrt{x} (1 - x^2) + (x - x^2)}{1 - x}
[/tex]
Schrodinger's Cat, you should start with the original equation and do the long division. You'll get the answer that I obtained in my earlier reply.
x^1.5-1+(1-x^1.5)
How did you get that part?
I did long division of the original equation.
Ok, but I still don't see how to get rid of the 1-x part.
I'll finish the long division though I can't remember it all that well.
What if you were working with:
[tex]
\frac{1 - x^2}{1 - x}
[/tex]
I'm getting something different. :uhh: Ordering the polynomials doesn't matter right?
So that should leave the equation at x^1.5(1+x)+x and therefore a limit of 3?
:uhh: How did you get 3?
So that should leave the equation at x^1.5(1+x)+x and therefore a limit of 2?
That looks like the right expression. You just plugged "1" in incorrectly.
Here is a JPEG image of what I did:
http://us.f2.yahoofs.com/users/415c3ee6z2007f18d/deepsleep_6er/__sr_/71b1scd.jpg?pfAN39EBK6njJ4lZ
Whoops!:yuck: Ok, got it.
The problem is that I never would've thought of that trick without outside help...
The pics kinda difficult to see but I still don't see how you got 3.
The pic should be easier to see now. I got 3 because the final (remainder) term can be factored to be (1+x^0.5+x) which is 3 when x = 1.
I can't even see the pic anymore. So you're supposed to base the limit on the remainder?
No, this is a special case. It just so happens that in this case, the x^1.5-1 cancels out when x = 1. The remainder becomes (1-x^1.5)/(1-x^0.5), which can be factored into (1-x^0.5)*(1+x^0.5+x)/(1-x^0.5). This factorization can be obtained by another long division.
  • #31
I can't read the jpeg for some reason, but I also got 3 by decomposing the numerator in the original equation (x^0.5-x^2) = x^0.5(1-(x^0.5)^3) which is a cubic and can be further factored as x^0.5(1-x^0.5)(1+x^0.5+x). The (1-x^0.5) cancel out leaving x^0.5)(1+x^0.5+x). Then take this limit as x goes to 1 gives 3. I imagine that's similar to what wurth did
1. How do I solve a limit algebraically without using the conjugate method?
To solve a limit algebraically without using the conjugate method, you can try using other algebraic techniques such as factoring, simplifying, or using trigonometric identities.
2. Why would I want to solve a limit without using the conjugate method?
The conjugate method is useful for solving limits involving radicals or complex fractions, but it may not always be the most efficient method. Solving a limit without using the conjugate method can help you practice different algebraic techniques and gain a deeper understanding of the limit concept.
3. Can I always solve a limit algebraically without using the conjugate method?
No, there may be some limits that cannot be solved algebraically without using the conjugate method. In these cases, you may need to use other methods such as L'Hopital's rule or numerical methods.
4. How do I know when to use the conjugate method and when to use other algebraic techniques?
It is important to understand the properties and limitations of each method when solving limits. In general, the conjugate method is most useful for limits involving radicals or complex fractions, while other algebraic techniques may be more suitable for other types of limits.
5. Are there any tips for solving a limit algebraically without using the conjugate method?
Some tips for solving limits algebraically without using the conjugate method include factoring, simplifying, and using trigonometric identities. It may also be helpful to review basic algebraic rules and properties, such as the distributive property and the rules of exponents.
