Solving Phasor Circuit: Finding Theta
In the discussion about solving a phasor circuit, the main focus is on finding the phase angle theta for the voltage across an inductor in a series circuit with an independent current source. The voltage is given as vL(t) = 3cos(wt + theta), and the impedance for the inductor is represented as Z = jwL. The relationship vL(t) = Z*I leads to the conclusion that the phase angle is 90 degrees, as the impedance is purely imaginary, resulting in an arctan of infinity. The conversation also touches on the use of textbooks in electrical engineering courses, specifically mentioning Nilsson and Riedel versus DeCarlo and Lin. Overall, the key takeaway is the understanding of how to derive the phase angle in phasor analysis.
EvLer
Hello,
now we are in phasors and I am missing something in this problem:
given a circuit of indep current source (5cos(wt)), R, L (with vL(t)) all in series, no values for them,
although voltage across inductor vL(t) = 3cos(wt + theta), we need to find theta.
So, by using impedance for L: Z = jwL, vL(t) = Z*I,
so I got vL(t) = jwL5 /_ 0 which is also = 3/_theta
And now what? The answer is 90 degrees, but how do I get it?
Thanks a lot.
The reason its 90 degrees is simple... the voltage is indeed ZI, and I has a phase of zero--- but you would do well to convince yourself that the impedance Z is purely imaginary, so you have a phase for your impedance equivalent to the arctan of Im[Z]/Re[Z] where Re[Z] = 0, and thus you have an arctan of infinity, which is undoubtedly equal to 90 degrees.
Therefore you have V = ZI which yields a phase of 0 + 90, the angular frequency and the amplitudes of Z and I are immaterial for this problem.
By the by, do you intro EE students still happen to make use of Nilsson and Riedel by any chance?
Huh?
I guess, not.
Thanks for reply!
Oh sorry, it's just a textbook that I found really great for my intro EE courses.
Thanks, I might check it out as complementary source. We are using DeCarlo and Lin, since DeCarlo is actually a professor here, I doubt they will change our texbook any time soon :rolleyes:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
