Solving Pinned Jointed Frame Exterior Reactions
  • Thread starter Thread starter matthew_hanco
    Frames
The discussion revolves around calculating the exterior reactions of a pinned jointed frame, focusing on the application of static equilibrium principles. Participants are attempting to determine the horizontal and vertical reaction forces at specific points, using moment equations and force summations.
  • Homework-related
  • One participant expresses uncertainty about how to calculate the exterior reactions, mentioning the need to take moments but feeling stuck.
  • Another participant attempts to calculate the horizontal and vertical forces using moment equations, arriving at a value for the horizontal force.
  • A third participant points out a potential error in the moment calculations, suggesting that the signs of the forces may need to be reconsidered.
  • Subsequent calculations yield different results for the horizontal force, leading to a comparison with a lecturer's answers, which differ slightly.
  • One participant suggests that the discrepancies in results may not be due to rounding errors and emphasizes the need for correct dimensions in the calculations.
  • A later reply indicates that the dimensions used in the calculations were incorrect and proposes a correction to the length used in the calculations.
Participants do not reach a consensus on the correct values for the reaction forces, with multiple competing views on the calculations and dimensions involved. Discrepancies between participant calculations and the lecturer's answers remain unresolved.
Limitations include potential missing dimensions in the provided diagram and unresolved mathematical steps in the calculations. The discussion reflects varying interpretations of the problem setup.
Students and practitioners interested in structural analysis, statics, and the application of equilibrium principles in engineering contexts may find this discussion relevant.
matthew_hanco
The problem is attached to this post, basically i need the exterior reactions and how to work them out.
i know i need to take moments I am just not sure how to work it out.
Basically what i worked out
is
i assumed horizontal members are equally to 1
sum of the horizontal = 0 5Kn- HA - HE=0
Sum of the vertical =0 10KN- VA =0
But that is where I am stuck i know the numbers should be roughly
HA=20
VA= 10
HE = 15
But i know it is more accurate than that I am not sure if i need to include sine or cosine in the solution
Thanx in advance
To add to it i have just tried
sum MA= 0
Therefore he x 2 - 5x1 - 10x2 =0
he =12.5
sum of horizontal 5+12.5 =17.5
therefore ha = -17.5
sum of the vertical
Va -10 x 1 =0
so Va = 10
Is that right?
Im desperate and really need someones help urgently.
matthew_hanco said:
sum MA= 0
he =12.5
Hi matthew,
Since you're taking moments around A and since the 5 kn and 10 kn forces produce opposite moments around A, one of your terms needs to be positive and one needs to be negative. You have a negative moment around A for BOTH of these forces.
Once you get the horizontal force from E you can sum forces and get the horizontal and vertical forces on A.
ok so the new calculated resultant forces would be
He= 15 ( (-10 x 2) - (+5x1) + He=0)
Ha= -20 (+15 + 5 - ha= 0 therefore Ha= -20)
Va= -10 (+10 -Va=0)
But now checking my lecturers answers he gives
14.82 for He
And a resultant force for a 22.2 acting 26.46 degrees from the horizontal
But with my results the resultant for a is 22.36 and 26.56 from the horizontal.
who is right, if he is how can i account for the discrepencies
Those answers are all pretty close, so I would guess the differences are in rounding error. Regardless, I can't check the math because the figure you provide has no dimensions on it.
All forces are in KN
I can see the forces. There are no linear dimensions on your picture.
matthew_hanco: The dimensions are already fully defined by the diagram given in post 1. The resultant reaction force at point A from your lecturer, 22.20 kN, is correct. However, the orientation angles given by both you and your lecturer are currently incorrect. The resultant reaction force at point A is 22.20 kN acting 26.77 deg from the horizontal. Keep trying. Your discrepancies are not due to round-off error. First, figure out the correct dimensions of your structure, and label them on your free-body diagram. You currently appear to be using wrong dimensions.
Got it, the length should be root 3 instead of 1.
so it should be
(-10 x (root3x2) - +5x1)/2=Ha
Excellent, matthew_hanco.
