Solving projectile motion equations
The discussion focuses on understanding the equation for projectile motion, particularly the presence of s^2 and delta t as two unknowns. Participants clarify that "s" represents distance and is not an unknown, while also explaining that units can be squared in physics. They highlight that acceleration is expressed in terms of length and time, leading to squared units like m/s^2. The conversation emphasizes the importance of recognizing how units operate mathematically, helping to resolve initial confusion. Ultimately, the exchange enhances comprehension of the underlying principles of projectile motion equations.
Femme_physics
Solving projectile motion equations...
Trying to understand this equation...
http://img541.imageshack.us/img541/2658/carqk.jpg
Uploaded with ImageShack.us
When you get to the end of this equation, there's s^2 and delta t..
That seems like two unknowns to me. How do they both cancel out?
Er... "s" is not an unknown. It is a unit for "seconds".
Zz.
Okay, but why is it in second degree? Why did they need to add ^2 into a unit?
Er.. it seems that you appear to not know that units can be squared, or undergo the same operations as a variable.
An acceleration, for example, is L/T^2, where L is length, T is time. So since the time dimension is squared, the units is also squared. In SI units, it is m/s^2. If you don't like the square symbol, then write it as m/ss. There, no more squared.
Zz.
Or as (m/s)/s: (meters per second) per second.
Ah...a little deeper ponderage after your replies got me to see the logic :) mercy.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
