Solving Proton Acceleration & Velocity: Conservation of Energy
fubag
[SOLVED] Conservation of Energy
A proton (charge e, mass = 1.67 * 10^-27 kg) accelerates from rest by crossing a potential difference V = 3.00 V
a.) Find the velocity v_0 it acquires?
(Suppose this proton, having initial velocity v_0 from part (a), moves from very away directly towards a stationary heavy ion which is singly charged, i.e. having the same charge as the proton, +e.)
b.) Find the distance r_min between the proton and the ion at the moment of closest approach?
c.) Find velocity v of a proton when it is at a distance r = 2r_min from the ion
a = (q/m)E
V = kQ/r
V = E*d (parallel plate)
I am literally stuck for part a into determining what it could be, it seems something is missing in the problem.
Please help.
Thanks!
What is the work done on a charge q when it goes from a point with potential V1 to a point with potential V2?
work done is the change in potential energy so (V2 - V1)*q?
I was wondering could I just integrate the equation a = (q/m)E into v = (q/m)*V? because electric field is the derivative of potential difference?
The change in KE is the work done. There's no need to integrate, since it is the potential difference which has been given.
I feel you should go through the basics once more by yourself.
I know change in potential energy = -Work
and that change in potential difference is the potential-energy change per unit charge...
so can't I just set Vq = U and then set that = (1/2)mv^2 and solve for v?
That's the correct way.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
