Solving Statics Ladder Problem: Understanding the Use of Trigonometry and Torque
  • Thread starter Thread starter webren
    Statics
The discussion focuses on solving a statics problem involving a ladder, where a firefighter's weight and the ladder's weight create forces that need to be balanced. The participant correctly identifies the forces acting on the ladder and sets up equations for equilibrium, finding the vertical force exerted by the ground to be 1300 N. The confusion arises in calculating the horizontal force, where the participant mistakenly uses the wrong trigonometric functions for torque calculations. It is clarified that the correct approach involves using the angle of 30 degrees for the components of the forces contributing to torque, as this reflects the perpendicular distance from the line of action of the force to the pivot point. Understanding the relationship between the angles and the forces is crucial for accurately solving the problem.
webren
Hello,
I am having a little trouble with this statics problem:
"A 15.0 m uniform ladder weighing 500 N rests against a frictionless wall. The ladder makes a 60 degree angle with the horizontal. (a) Find the horizontal and vertical forces the ground exerts on the base of the ladder when an 800-N firefighter is 4.00 m from the bottom."
In solving this problem, the first thing I did was draw a free-body diagram of the scenario and label all the exerting forces. The forces that I came upon were the force of the wall exerting on the ladder (Fw), the weight of the ladder (WL), the weight of the firefighter (WF), and the x and y components of the force of the ground exerting on the ladder (Fxg and Fyg).
The next thing I told myself was: because the ladder is at rest, it is in equilibrium, so the net force and torque will be zero.
I go ahead and start my sum of forces in the x and y directions:
Fx = Fw - Fgx = 0.
Fx = Fgy - WL - WF = 0.
Because the weight of the ladder and firefighter are given, I was easily able to solve for the Fgy component which came out to be 1300 N.
My problem lies in solving for the Fgx component. This is my attempt:
I realized that because torque (t) is equal to force multiplied by distance (fd), I would need to use it to solve for the Fgx component. Therefore, I created my sum of torques:
t = -800(4)(sin60) -500(7.5)(sin60) + Fw(15)(cos30), and I solved for Fw which came out to be 4.63 N.
In my above equation, the 4 comes from the distance the firefighter is standing from the base of the ladder, the 7.5 is the center of gravity of the ladder (halfway point of the ladder), and the 15 comes from the total length of the ladder because the force of the wall is at the top of the ladder. All of these values are in meters.
I think my problem lies in me possibly using the wrong trig function and/or angle value. It looks like if I used 30 degrees instead of 60 for the above first two trig function values, I get to the right answer. Why is it mandatory to use 30 degrees instead of 60 when the problem specifically states the angle is "60 degrees with the horizontal" - which is right at the base of the ladder and the ground. I understand that the other angle of the formed triangle would be 30 degrees, but why use that angle instead of 60 degrees?
I hope my question/analysis isn't confusing. Thank you for your time and help.
Everything up to here is correct.
The first 2 terms in that expression have the wrong trig functions in them. Do it again - draw the triangles, label the correct sides, write out the ratios carefully and find the required unknowns.
Remember that the 'd' in the torque equation is the perpendicular distance from the line of action of the force to the chosen point.
PS: Note that cos30=sin60
webren said:
Hello,
Fx = Fw - Fgx = 0.
The reason you must use sin(30) (or cos(60)) comes from the definition of the torque.
Look at the weight of the ladder, say. The component of that force that contributes to the torque is the component that is *perpendicular* to the ladder. And that component is WL sin(30).
In general, you must take the component of the force that is perpendicular to the line joining the axis of rotation to the point where the force is applied.
If you look at the force exerted by the wall on the top of the ladder, you will see that the part perpendicular to the ladder is FWFW cos(30) so that part was right.
I understand. Both of you explained it very well. Thanks.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
