Solving Tension Ratio of Steel Wires with Hooke's Law
  • Thread starter Thread starter cremedelacreme
    Tension
The discussion focuses on calculating the tension ratio of two steel wires, P and Q, under the same extension using Hooke's Law. Wire P has a length l and area A, while wire Q has a length of 2l and area A/2. Participants emphasize that stress and strain must remain consistent for both wires, as dictated by Young's Modulus. The calculations indicate that the tension in wire Q should be four times that in wire P, leading to a tension ratio of 4:1. Clarifications are sought on how to ensure that the force applied results in equal stress and strain for both wires.
cremedelacreme
Two steel wires P and Q have lengths l and 2l respectively and cross sectional areas A and A/2 respectively. Both wires obey Hooke's Law.
What is the ratio (tension in P/tension in Q) when both wires are stretched to the same extension?
You must show an attempt at solving this before we can help you (forum rules).
Yeah, I got it but it's not the right answer...
If you post your attempt, perhaps we could help you out.
F/A divided by Difference in L/L
Since
Stress/Strain
Thus Fl/A(Difference in L)
L is doubled
Area is halved
hence in Q it should be 4
while in P it is 1
But the answer says that it is 4:1
That's a good attempt, you're very close.
Stress/Strain must be the same for both wires, since that is Young's Modulus for the material.
As you said, (L/A) is a factor of 4 larger for Q.
What must F be for wire Q, in order that the ratio
F L/(A ΔL)
be the same for both wires?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
