Solving the Convection-Diffusion Equation for this Pipe with a Heat Sink
  • Context: Graduate
  • Thread starter Thread starter HumanistEngineer
    Heat Heat sink Pipe
The discussion revolves around solving the transient temperature propagation through a buried insulated pipe using the convection-diffusion equation, particularly focusing on the effects of a heat sink due to heat loss from the water mass to the ground. Participants are analyzing numerical methods and finite difference approximations related to this problem.
  • One participant shares their approach to solving the convection-diffusion equation and requests feedback on their finite difference approximations.
  • Another participant suggests that the initial results appear acceptable but does not provide further clarification.
  • A participant notes that the last term in the differential equation should include a heat transfer coefficient and asks for the derivation of that term, as well as the inlet and initial conditions.
  • Further clarification is sought regarding the term involving the heat transfer coefficient, specifically questioning the inclusion of the factor 4/D in the equation.
  • A participant provides a detailed finite difference form of the balance equation over a segment of the pipe, discussing the relationship between various coefficients and the temperature gradient.
  • Participants discuss the initial conditions, stating that the water temperature starts at 50 °C and is increased to 70 °C, while the ground temperature is held constant at 10 °C.
There is no clear consensus among participants, as some express uncertainty about specific terms in the equations and the derivation of coefficients, while others provide differing viewpoints on the numerical analysis and its results.
Participants have not resolved the assumptions regarding the heat transfer coefficient and its derivation, nor have they clarified the implications of the finite difference approximations on the results. The discussion includes various mathematical expressions and conditions that remain open to interpretation.
HumanistEngineer
TL;DR
Temperature propagation through an insulated pipe in time
The solution of convection-diffusion equation with a heat sink (heat loss from pipe to the ground)
Hi Again,
I try to solve the transient temperature propagation through a buried insulated pipe by means of solving the convection-diffusion equation with a heat sink that is the heat loss from the water mass to the ground. Below you can see the details of my calculation steps in my numerical analysis.
The problem is that my results are oscillating and/or abnormal. Would you please check my finite difference approximations, if they are correct or not?
Details:
245081
It looks OK. So??
Here is the result (for different mesh numbers). The maximum (steady-state) temperature should be at around 70 °C.
245317
That last term in the differential equation should involve a heat transfer coefficient. Please provide the derivation of that last term in the equation. What is the inlet condition and the initial condition? What is the temperature of the ground?
I get $$c=\frac{h}{\rho C}\frac{4}{D}$$where h is the heat transfer coefficient
Thank you Chestermiller for your time. You indicated c as c = h/(rho cp) (4/D) . Why is there this 4/D?
I use the thermal resistance, R [K/W], in the last term c, which means that h=1/R. Here how R was derived:
The initial condition for the pipe is that the water temperature is initially at 50 °C and in my numerical example the inlet water temperature is increased to 70 °C. Then the aim is to see how the temperature propagates through the pipe length in time. The ground temperature is constant at 10 °C.
If U is the overall heat transfer coefficient based on the inside diameter of the pipe, then the balance equation over a length ##\Delta x## of pipe, in finite difference form, goes like:
$$\rho C_p\left(\frac{\pi d_i^2}{4}\Delta x\right)\frac{\partial T}{\partial t}+\ ... \ =\ ...\ +\pi d_i\Delta xU(T-T_{ground})$$
If we divide this by ##\rho C_p\left(\frac{\pi d_i^2}{4}\Delta x\right)## and take the limit as ##\Delta x## approaches zero, we obtain: $$\frac{\partial T}{\partial t}+\ ...\ =\ ...\ +\frac{U}{\rho C_p}\frac{4}{d_i}(T-T_{ground})$$
Here, $$\frac{1}{Ud_i}=\frac{1}{h_{flow}d_i}+\frac{1}{2\lambda}\ln{(d_{o}/d_{i})}+...$$
Note that ##\Delta x## is not present here.
  • · Replies 23 ·
