Solving the Critical Radius for Relativity: Find krE!
  • Thread starter Thread starter n1caboose
    Radius Relativity
n1caboose
Special Relativity states that a clock orbiting Earth will tick slower than one on the surface of Earth. General Relativity states the opposite - a clock will tick faster the further it is from a mass. Is there then a critical radius where these two effects cancel out? Ignore the rotation of Earth for this problem. State the radius in terms of rc=krE, where k is the number to be determined and where rE is the radius of the Earth.
-This was the extra credit problem on my Relativity final which I really wish I could have solved. Anybody want to take a shot at it?
Yes. If you want to take a second stab at it, consider the following:
An object on the surface of the Earth, ignoring the Earth's rotation, will have a "time dilation factor" of
\sqrt{1 - \frac{2GM}{c^2 r_E}}
An object in orbit about the Earth at some radius r will have a "time dilation factor" of
\sqrt{1 - \frac{2GM}{c^2 r} - \frac{v^2}{c^2}}
where v is the orbital velocity at radius r. (Can you see how to get this result?) These two facts are enough to get the answer you seek.
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
